Old 11-07-2014, 10:27 AM   #2115
Racecomp Engineering
Originally Posted by bjun View Post
I don't feel like I'm too low. I don't find it difficult driving on normal streets. I am still like 3 inches off the ground on front and like 5 inches in rear from the rear diffuser. However, I am on max low on front as KW will take me(I know this is bad for handling) but in the rear my coils have plenty more to drop.
Do you have a picture?
- Andy
Old 11-07-2014, 10:39 AM   #2116
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
But I've tracked like this before and it wasn't so bad.
To change that into "it was great!" instead of "wasn't so bad", raise your car. No lower than 4.75" from the pinch welds.
raul is offline   Reply With Quote
Old 11-07-2014, 10:49 AM   #2117
bjun
bjun's Avatar
Drives: white premium brz M/T
Originally Posted by jvincent View Post
@bjun, please don't take this personally, but have you read the following thread?
http://www.ft86club.com/forums/showthread.php?t=67345
Yes, I have. The only problem I have that is listed is the drop of coilover.
- Andy
Only decent picture I have at the moment
bjun is offline   Reply With Quote
Old 11-07-2014, 10:56 AM   #2118
Hard to tell. Car looks nice but I would probably raise the rear slightly and maybe the front. KW V3 are good coilovers when set up well and a great coilover for someone that's new to the track. But you gotta have them set up well.
Either way, you need more front camber...max it out at the lower mount since you don't have plates and you'll be in good shape (though a little more would be better). Reduce rear camber when you get your LCAs to around -2.2 or so.
- Andy
Old 11-07-2014, 11:04 AM   #2119
bjun
bjun's Avatar
Either way, you need more front camber...max it out at the lower mount since you don't have plates and you'll be in good shape. Reduce rear camber when you get your LCAs to around -2.2 or so.
- Andy
Thanks! Was planning to lower front to -2 and rear to -2.5 but I'll go with -2.2 rear now
Old 11-07-2014, 11:06 AM   #2120
You'll want more than -2 front if you can get it.
- Andy
Old 11-07-2014, 11:11 AM   #2121
bjun
bjun's Avatar
- Andy
What would be your recommendation? similiar to rear?
Old 11-07-2014, 11:20 AM   #2122
As much as you can get honestly. Without plates with V3s you can still get a decent amount....maybe -2.5 or so (off the top of my head).
- Andy
Old 11-07-2014, 01:18 PM   #2123
sw20kosh
Drives: 2013 Black FR-S
If you can't get much neg camber in the front I would start looking at camber plates. -3.5 since your car is not a daily.
And yes raise your car. You want to regain suspension/shock travel.
Old 11-07-2014, 01:27 PM   #2124
Yes, you should think about getting some camber plates.
- Andy
Old 11-07-2014, 01:41 PM   #2125
Generally speaking, you want to start at -3 in the front, and adjust accordingly for the front, based on your own needs
Rear will usually fall between -2 and -2.5
Old 11-08-2014, 11:34 PM   #2126
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
So, I have an issue with my car. When taking high speed corners (60 mph+), I'll have my steering wheel set at a certain angle and I'll be controlling the angle with the throttle.
However, despite holding the wheel at the same angle, the car will suddenly veer violently into the turn (for example, if I'm taking a right turn, it'll suddenly veer violently right). This is really scary and I'm not sure why the car does this. It usually happens when there are downward elevation changes or dips.
I have stock suspension, stock tires, and a DriveWay Labs diffuser. I have hit a curb and set my alignment off a while ago, though I had it realigned at Toyota back to stock specs.
sittinSideways is offline   Reply With Quote
Old 11-09-2014, 12:29 AM   #2127
Stability control on or off?
What kind of tires?
If VSC on, it's probably fixing a driving error (preventing a spin). If VSC is off, thats you losing/gaining traction over the dip, possibly from inner wheel spin, sudden traction loss, not enough droop, or running out of bump travel..
Fix it with either an LSD, better suspension, or both.
Old 11-09-2014, 07:57 PM   #2128
BRZbro
Drives: 2015 BRZ Sport-tech
I don't think any additional cooling should be necessary while naturally aspirated.
Due to the design of the OEM radiator, I much prefer using powerful fans over replacing the radiator, particularly when you start stacking cores like we do, and the flow drops.
In our case, we have FMIC, 2x Setrab coolers, AC condenser, and then Radiator.
^ is what you said in a previous post on a different thread. I'm just wondering what is your real input on the rad. You put a larger rad on your top 10 mods. Thanks!
BRZbro is offline   Reply With Quote
