| View the official forum sponsors list |
#57 | |
Grand PooBah
Drives: Toyota 86 GT MT
lol my bad! saw the photos at the top of the thread and hit reply... from there is looked like it was just like the grill and open to air. i wonder if some creativity with a dremel couldnt make these cross functional.. |
#58 | ||||||
Drives: FRS
PICTURES OF ITEM ON FRS UP ON THREAD.. thanks |
#59 |
Pull my finger...
Drives: Silver Scion Slushbox
LOL I was begining to think I was losing it. Yeah, I'm sure it could be done.
#60 |
Drives: Ultramarine frs
Can you get some front shots like the first pix but a bit further away?
Tap'd via G-Note2...
#61 |
Drives: it like he stole it!!
#62 | |
Drives: Scion FR-S
Won't this blind drivers at night? |
#63 |
Drives: Firestorm FR-S
Looks sweet! More pics!
#64 |
Drives: 2013 Scion FRS
I don't think so as they are too low on the car. Whereas high beams direct light up and out. I also don't think these are as bright. Especially considering they are in the same spot as fog lights and people drive with those on all the time.
#65 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Here is a better pic of the LED yours looked yellow.
#66 |
Road Warrior
Full power
| The Following User Says Thank You to Ryan86 For This Useful Post: | Tylub (01-25-2013) |
#67 |
Ok so I will be the first FRS in the U.S. to have these and I am doing the DIY. I am curious as I have not received mine yet how do you switch from dull to full power? Is there something on the wiring to switch it? |
#69 |
Pull my finger...
Speculating here but if you tap into the high beams, the DRL will drive them at the low setting and turning on your brights would bring about the brighter setting?
I thought I saw a little module in the wiring pics that I think is what would allow this to happen. If you have LEDs in your high beams then that may be of some benefit but if you've disabled them then you might want to find a different power source and bypass the module. I believe the module uses the two different voltages that are present with a DRL setup. |
#70 |
Road Warrior
You probably correct, will have to wait and see.
I was hoping this just plugged onto the GT86 fog light without any wiring needed. Slightly different for the FRS.. The price is right at $180 shipped anywhere in the world. |
| "LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" | F-T | Exterior Parts - Lighting | 169 | 08-20-2016 02:15 PM |
| LED daytime running lights | sav | AFRICA | 168 | 03-22-2016 05:26 AM |
| Front LED Daytime Running Lights | myjobis2pimp | NY / NJ / CT / PA | 0 | 04-18-2013 06:47 AM |
| ***FR-S/BR-Z LED Daytime Running Lights 6K White*** | Vicious LED | Exterior Parts - The Rest | 7 | 10-14-2012 04:38 PM |
| daytime running lights | JDMrolla | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-06-2012 11:09 PM |
