Old 01-21-2014, 07:40 AM   #15
Ongor
Drives: 2013 Scion FR-S, Hot Lava
Wow, thanks for the replies and suggestion guys, much appreciated!
I'm now torn between only 2, and that's petty good news for me!
Fortune Autos, or STs. ST's come without Camber plate nor Dampening adjustment, but they're much cheaper also.
It seems like the question now is, do I really need/want those 2 features? are they going to be a pain or a blast to adjust? (I'm the kind of person that likes tweaking stuff :P )
Again, tx for the imput!
Ongor is offline   Reply With Quote
Old 01-21-2014, 07:45 AM   #16
Ongor
I read somewhere that the ST's are not made in stainless, any idea what they're made of? Rust is a big deal here in Montreal :S
Old 01-21-2014, 10:26 AM   #17
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
ST's are high grade steel with a zinc coating for rust protection. Id probably stick with stainless options if you're driving the car through salty winters. And especially if you want to continue to be able to change the ride height every season (once that rusts it's going to be a pain to adjust them again).
I'd save a bit more and go with the KW V3's, you can get better than stock ride quality on the street, it's an amazing damper system, they're stainless steel, lifetime warranty, and you get the adjustments that you said you'd enjoy tweaking around.
Anomie is offline   Reply With Quote
Old 01-21-2014, 10:41 AM   #18
Malt
Drives: 2015 WRX
Personally I didn't see many options for coilovers that were actually an upgrade over the stock suspension below the ~$2000 mark. I really depends on what the OP wants. If he just wants to lower the car a bit then just get lowering springs and call it a day. No need to put cheap coils on the car and end up with something that handles and rides worse than stock.
If you are considering saving up for the V3's you might as well save a bit more and get some RCE T2's. Better than V3 plus you'd get amazing support from Myles at racecomp engineering.
EDIT: Looks like I fail at reading comprehension. Lowering springs won't work for you. ST's are great coils at their price point but you will have rust issues. My suggestion would be to save up a bit more money and get either KW V3's or RCE T2's. The T2's are more track oriented but ride as good or better than stock. The V3's I've heard can be tuned to ride much better than stock and are slightly cheaper than the T2's. Either way both have a lifetime warranty through KW.
Malt is offline   Reply With Quote
Old 01-21-2014, 11:24 AM   #19
df.dima
Drives: FR-S and Mazda 3 Sky
Why not look into RCE T0s?
df.dima is offline   Reply With Quote
Old 01-21-2014, 01:37 PM   #20
Racecomp Engineering
KW V1 or RCE T0 for the stainless finish. Can't get quite up to stock ride height but close.
RCE T0 are made by KW and are a slightly more sport version of KW V1. Both have good ride quality around a 1.5 inch drop.
I would at least recommend something that reuses stock top mounts.
- Andy
Old 01-21-2014, 02:48 PM   #21
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
skip fortune.Long story, i havent posted my story about them yet. But if ur looking to track or even DD LOL dont get the 500. I nicked the curb around 25mph and the suspension just snapped. my XXRs had a tiny outer lip bend and that its. the entire suspension snapped. Better yet when i called in they charged me to get a replacement set out. If fortune coil cant handle a nick, how can it deal with track especially if you hit apex's or slide off the track? On the other hand.. i gotta congratulate xxrs for holding up LOL
Edit: Go for ST. the BCs over time tend to have spring bind and noises same as the fortunes. At least the STs have been designed by someone who knows what they are doing. As long as ur not looking to slam, it should provide you with sufficient shock travel. Also plan for how much you really want to drop and find a coil that is optimal for that height.
umpadupa is offline   Reply With Quote
Old 01-21-2014, 03:33 PM   #22
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
ST coils and call it a day. Close this thread.
hanabie is offline   Reply With Quote
Old 01-21-2014, 03:42 PM   #23
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
it sounds like bilstens would be a great fit for you
asdf is offline   Reply With Quote
Old 01-21-2014, 06:39 PM   #24
KayC
Drives: 2013 whiteout FRS 6mt
I would Skip the ST. Being in Montreal you will see a fair share of salty road days. your best bet would be kwv1, RCET0, bilstein b14
KayC is offline   Reply With Quote
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 02:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
Stiff coilover options? YDNA Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-05-2013 10:33 AM
86Drift Coilover Options for Australia 86drift Australia Classifieds 8 02-27-2013 06:11 AM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 08:19 AM
