Drives: None
Torque specs on exedy stg 2 clutch?
I recently ordered an exedy stage 2 clutch for my frs and am wondering what the torque specs are for when I install it. Which bolts require torque specs that I need to look out for, and how much are they. I know I am going to need to remove the shifter, and remove remove the starter if necessary I believe. But if I remove the starter, would I need to tighten it at a certain spec? Also, when i re bolt the transmission back on the block, will i need to torque it down at a curtain spec? I know for sure the clutch and clutch disk need to be torqued down, but at what spec? Thanks
Sent from my LG-D850 using Tapatalk |
| Exedy Clutch | KAR | Engine, Exhaust, Transmission | 28 | 01-03-2016 08:27 PM |
| FX300/FX350 Clutch or Exedy Stage 1/2 Clutch? | bren5279 | Engine, Exhaust, Transmission | 8 | 09-22-2015 11:36 AM |
| OEM Exedy clutch on backorder | radroach | Engine, Exhaust, Transmission | 1 | 03-13-2015 12:30 PM |
| Anyone know the wheel specs on the exedy toyota 86? | JasonCDC | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-09-2013 03:33 PM |
| Exedy BRZ specs sheet | ayau | BRZ Photos, Videos, Wallpapers, Gallery Forum | 2 | 11-07-2012 10:56 PM |
