| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Blue Scion FR-S
Best Wheel Size?
What is the best wheel size for the FR-S that will NOT cause rubbing?
#3 |
TRACKBREAD
Just kidding, but that's a very vague question. Best for what? Track days? Drag racing? Showing off? Hard parking?
-Josh |
#4 |
#5 |
TRACKBREAD
Honestly depending on the tire compound, stock tire size can handle a turbo just fine.
That said, people are running 255s on this car with minimal problems, do some digging in the forum, you'll find plenty of options! -Josh |
#6 |
Drives: Ultramarine toyobaru
Stock specs are the best for everyday driving and hooning. Throw some spacers on if you want more flush.
#7 | |
Drives: 2015 Subaru BRZ
What are your horsepower goals for your turbo? At 250hp you can get away with sticky 225s on the stock wheels; at 500hp+ you're gonna be looking into 18x10's. Easiest answer is go buy some 17x9s in 42 to 35 offset. They'll fit 245-255 width tires and be good for both NA an FI. |
| The Following 2 Users Say Thank You to Hostile_Kittens For This Useful Post: | DarkSunrise (08-29-2016), JazzleSAURUS (08-29-2016) |
#8 |
Drives: 2014 GT86
BTW, spacesaver donut wheels are shure to not rub on FR-S. If they clear calipers that is
#9 |
Drives: 15 BRZ LTD, 05 FXT
17x8 or so with some 235's now in something like an S-04 or PSS will be a huge improvement now, and with FI, and will hold up decently for boost, and if you decide you want more you can step up to stickier rubber.
#10 |
Drives: 2013 Raven FR-S
IMO the best size wheels for stock-ish power levels is 17x8. That holds a 225 tire really well, but you can still run 245 if you need to.
#11 |
TRACKBREAD
#12 |
Agree with this. If you're adding a turbo, just go straight to a 9" wheel.
2022 BRZ Build 2013 FR-S Build |
| Wheel Spacer Size?? | tonytduc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 52 | 11-03-2018 04:36 AM |
| Wheel size needed | FRSssh | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-28-2015 02:00 AM |
| Wheel/Tire size help!!! | jordanlee2393 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-07-2015 07:11 PM |
| FI and wheel size. | Adeets | Forced Induction | 41 | 05-24-2013 01:23 AM |
| Wheel Size vs. Balance | jellygorilla | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 09-11-2012 02:23 PM |
