Not a troll
Stock suspension
Ok, so the situation:
I'm currently on coils, but ideally would like to return to my stock suspension for the winter. I switched over the front pieces no problem, then got the rear disassembled without issue. The trouble is, once I get onto the re assembly of the rear, I can't get the lca to bolt up. I can either attach it to the hub or the part by the diff, but not both. Is this due to my toe arms? Is there anyone who had been through the same process and has any tricks to getting this accomplished? |
#2 | |
That Guy
Drives: 2013 asphalt FRS MT
#3 |
Not a troll
Has nothing to do with the sway bar. It's like the LCA is too long to go between the hub and the frame (?) connection point.
#4 | |
hey you, yeah you <3
Drives: 2014 37J FR-S
Found it...derp lower control arm. (no coffee yet) Tried moving wheel assembly to see if it moved?
#5 |
That's impossible based on how the suspension works, unless you're blocking the wheel from changing camber angle. Tilt the bottom of the hub outwards and there will be plenty of room to get the LCA in.
| The Following User Says Thank You to wparsons For This Useful Post: | Calum (10-03-2015) |
#6 | |
Not a troll
One of us was pulling on the hub, the other was trying to get the lca lined up to the bolting point. It just wouldn't go. I'm seriously confused at this point. Could it have something to do with my toe arms? Edit: ok. Got the LCA on now. However, can't get the oem struts in there. Last edited by Cole; 10-03-2015 at 12:14 PM. |
#7 |
Not a troll
This has been sorted. Spent 30 minutes on one corner and got the strut and lca bolted up. Not sure what I was doing wrong yesterday...
#8 |
Next time you're trying to get the shock(s) in there, disconnect one sway bar end link. It'll make your life MUCH easier.
| The Following 3 Users Say Thank You to wparsons For This Useful Post: |
#9 | |
Not a troll
It was such a weird thing. It could have been due to frustration, or maybe the order I tried bolting it up in. I don't know, but it seemed absolutely impossible. Anyways, got it done, now just waiting on an alignment when I have the time. Have to remember to bring my camber bolts when I take it in. |
#10 |
Sometimes, the best solution is to call it a day, have a beer, then try again the next day lol.
| The Following 4 Users Say Thank You to D_Thissen For This Useful Post: |
#11 | |
Not a troll
The second attempt, I ended up really hurting my arm while undoing some bolts, so I was taking a bunch of breaks and just taking a good look at what was going on during the install. Funnily enough, I've done aftermarket coils and RLCAs on my car and a friend's car in my garage and both of those installs went off without a hitch. The whole going back to stock was the real problem and I don't even know why. Most likely due to rushing it and not taking my time to actually troubleshoot. |
#12 |
Thanks
Sometimes it helps to have someone stand on the hub lol
#13 |
The Fail Boat
Drives: CWP S.B.
| FS Stock Suspension and stock exhaust Illinois | Full_Throttle_86 | Great Lakes | 2 | 09-24-2015 10:44 AM |
| WTB stock rear tophats or complete stock suspension | s13kid989 | Want-To-Buy Requests | 3 | 10-09-2014 07:11 AM |
| Mix & Match stock FR-S and stock BRZ suspension and/or springs | Weasel Soup | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 09-08-2014 01:53 PM |
| Fs stock 86 suspension | Carlie | Australia Classifieds | 0 | 03-28-2014 08:19 PM |
| FS: Stock FR-S Suspension | Kai Uhl | Brakes, Suspension, Chassis | 4 | 08-20-2013 10:41 PM |
