Drives: Black BRZ
FS: Chiptorque XEDE Processor (Piggy back ECU)
For Sale: Chiptorque XEDE Processor (used). $600 plus shipping
Fitted to my BRZ with a custom dyno tune for a full header back exhaust and aftermarket intake. Custom map included and standard maps available from manufacturer. Plug and play. You don't need to touch the factory ECU, so good for those who want to maintain factory warranty. Overview: The XEDE is an interceptor style Engine Management System. It generates changes in fueling and ignition timing by changing the factory ECU’s load and crank reference input signals. It has the additional functions of two stage intercooler water spray control or potentially any other on/off or PWM function including injector drive for an additional injector. The XEDE can generate data logs and importantly can also store two separate programs which can be changed at the flick of a switch – 98 Octane or E85 fuel maps. The XEDE Processor is a sophisticated tuning tool that gives any dyno programmer control over the engine management system without having to learn the fine nuances of each vehicle’s engine management system. The web based XMap software is available free to custom tune for accurate results. How the XEDE Works: The XEDE Processor integrates with an existing (usually factory) Engine Management System. The operation of the XEDE is to modify the signals from the Air flow meter / Map sensor and the Crankshaft position sensor before the factory ECU sees the signals. By changing the values of these signals, the resultant outputs from the ECU will be changed. Benefits: The benefits of using an XEDE over other tuning options are: Most factory parameters are retained Cold start functions Idle control Knock sensor functions Closed loop control Limp home operating strategies Fan and Air Conditioner controls Immobiliser functions Customer Support: Ongoing local Research & Development Tuning email and phone support available General Features Base program downloaded to suit specific application Two unique tuning map banks that allow optional setup for dual fuel map operation switched via a dash mounted switch Up to 400 adjustment points per tuning map Optional output for auxiliary boost injector or intercooler water spray Unit has a fully sealed, rugged and lightweight housing Live data display through XMap tuning software. |
| Tags |
| ecu, tune |
| Our Back to Back Savings Continue with our 2015 Memorial Day Sale! | FRSport.com | Announcements, Contests, Giveaways | 0 | 05-22-2015 09:10 PM |
| Axle back exhaust feed back requested | Gruppe-s | Engine, Exhaust, Transmission | 10 | 12-10-2014 08:56 PM |
| 18x8.5 with 235x35 on all 4 corners OR 18x8 front + 18x9.5 back 235/35 + 255/35 back | KSpider | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 09-14-2013 08:06 PM |
| Possible trade? Nameless axle-back for Perrin Resonated Cat-back | GTB/ZR-1 | Engine, Exhaust, Bolt-Ons | 0 | 03-26-2013 02:51 PM |
| Drove the 86GT and NC miata back to back on GT5 | Hanzo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 39 | 01-07-2012 01:56 PM |
