Old 06-29-2015, 02:37 AM   #1
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Bespoke headunit into FRS with regular radio
Does the bespoke frs head unit plug and play into FRS models without the bespoke unit?
If not, whats needed to convert?
If it fits perfectly, please let me know!!
Thanks!
Decimus is offline   Reply With Quote
Old 06-29-2015, 10:24 AM   #2
Chimera
Drives: FRS
Should be plug and play.
Old 06-29-2015, 11:29 AM   #3
It's plug and play. I replaced the 2013 basic headunit in mine with a 2014 unit with GPS. The whole process took 30 minutes, which included mating the GPS unit to the BeSpoke unit (I purchased them from two separate sources) and figuring out where I wanted the GPS antenna.
Old 06-29-2015, 12:07 PM   #4
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Thank you all!
Old 06-29-2015, 06:54 PM   #5
SisterBlue22
SisterBlue22's Avatar
Drives: "Frances" - 2013 FR-S in Firestorm
Yep, I just made the same swap in my 2013...removed the non touchscreen HU and replaced it with the touchscreen model from a 2014/2015 (I liked it better than the 2013 touchscreen model). I'm a mechanical idiot and I got it done, with an assist by my son...hardest parts for me were getting the trim panel off, and unplugging the damn connectors from the back of the unit. I did not add the navigation module, as I don't need it, so technically I don't have the Bespoke upgrade...just the touchscreen, which is all I wanted.
SisterBlue22 is offline   Reply With Quote
BeSpoke Premium Headunit Bespoke Software? vinh359 Electronics | Audio | NAV | Infotainment 5 05-16-2015 11:14 AM
fs: bespoke headunit Sangthing Audio/Visual, Electronics, Infotainment, NAV 4 03-12-2015 12:00 AM
Bespoke Headunit CanibeatNoel Audio/Visual, Electronics, Infotainment, NAV 0 09-02-2013 09:39 PM
FS: Bespoke Headunit Hanakuso Audio/Visual, Electronics, Infotainment, NAV 4 06-19-2013 11:06 PM
