Old 07-01-2015, 07:45 PM   #1
burdickjp
Drives: 2013 ultramarine Scion FR-S
Lug nut torque investigation?
I was scratching my head about how high the lug nut torque is after 5 of my wheel studs sheared off last time I pulled my wheels.
Even more curious to me is that the current Impreza, which has very similar running gear, is apparently 92 N*m (according to a quick internet search) compared to the 120 N*m the BRZ calls for. Anyone look into this?
burdickjp is offline   Reply With Quote
Old 07-01-2015, 08:01 PM   #2
vroom4
Are you confusing N-m and ft-lb? 90 ft-lb = 120 N-m....basically every lug nut Ive ever tightened has been to this spec and I have never broken a stud.
Ive had the wheels on and off my brz at least 300 times....still on stock studs.
vroom4 is offline   Reply With Quote
Old 07-02-2015, 12:22 AM   #3
burdickjp
I don't work in archaic units.
I had some tires installed in January. I'm guessing the wheels were installed with an impact.
Sent from my XT1045 using Tapatalk
Old 07-02-2015, 12:30 AM   #4
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Yeah, this is probably more than likely. I've only had one good tire shop experience in my entire life.
jawn is offline   Reply With Quote
Old 07-02-2015, 12:35 AM   #5
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I only let tire places mount the tires to the wheels... will never let them put the wheels on the car, I do that myself PROPERLY by hand and then torque down to 81ftlb! Too many issues with tire places in the past...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 07-02-2015, 12:36 AM   #6
burdickjp
This was a Toyota dealership.
Old 07-02-2015, 11:44 AM   #7
vroom4
Wheels were installed with impact, you work in NO UNITS apparently
End thread. There is nothing wrong with OEM studs, just users.
The Following 4 Users Say Thank You to vroom4 For This Useful Post:
jawn (07-02-2015), Kuri (07-02-2015), Rabbit of Caerbonnog (07-02-2015), srizzors25 (07-02-2015)
Old 07-02-2015, 12:10 PM   #8
Run Away!
Rabbit of Caerbonnog's Avatar
Drives: 2015 Subaru BRZ Limited
Rabbit of Caerbonnog is offline   Reply With Quote
Old 07-02-2015, 12:18 PM   #9
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
May as well get some cool studs like ARP's, and use a torque wrench, while not letting dopes near your car. That solves most of the problems.
JazzleSAURUS is offline   Reply With Quote
Old 07-02-2015, 12:43 PM   #10
burdickjp
I wasn't the last person to touch them, and I'm sure that was the problem, but in my investigating I found a difference and am wondering why it is.
Why not be a little nicer?
Yep, got ARPs on the front now to accommodate spacers to accommodate my new front calipers.
Old 07-02-2015, 12:46 PM   #11
srizzors25
Daedalus Moto
srizzors25's Avatar
It's possible they could have been weakened by improper install (install with impact) and just so happened that they reached their breaking point at the most recent install even under proper torque.
Be careful with your other lugs in the future. If you sheared 5 off, chances are a good amount of your studs are probably on the edge as well.
Old 07-02-2015, 12:51 PM   #12
vroom4
Sorry typing from phone, try to keep it short. Disregard "meanness"
Old 07-02-2015, 12:55 PM   #13
stugray
Drives: 2013 GBS BRZ Limited
That's a sure fire attitude to get your car messed up.
How many mechanics in the US do you think can convert to/from metric in their heads.
Learn to speak the language of the natives and you will get much accomplished.
It is sad that the US still uses "archaic units" but denying that fact is not prudent.
Old 07-02-2015, 01:35 PM   #14
burdickjp
I replaced the fronts with ARPs and the backs with the studs which came with my Eibach spacers. They were shorter, so I could install them without pulling the rear hubs. I wasn't in a position to make an adapter for my slide hammer to pull the rear hubs out, so it was a good thing that these spacers came with studs!
I genuinely appreciate the apology.
But really. Does anyone have any ideas as to why the BRZ would have different torque specs to other Subarus, when it shares parts, or did I just find the wrong info for other Subarus?
The Following 2 Users Say Thank You to burdickjp For This Useful Post:
Butterballz (05-28-2018), vroom4 (07-19-2015)
Requested torque and Calculated torque nickw14 Software Tuning 3 06-13-2015 05:09 AM
What torque dip? GeeTee86 AFRICA 33 05-25-2015 10:55 AM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 01:22 AM
Investigation into Toyota pedal problems widens nisarnadaf Other Vehicles & General Automotive Discussions 0 02-04-2010 02:57 AM
