Old 11-24-2012, 04:50 PM   #1
Doc
Doc's Avatar
FRS Radar Detector Easy Hardwire
Hey guys. Here is FYI for FRS owners who want to hardwire their radar detector but don't want to run the wires to the fuse box or accessory plug.
If you pop out the dome light (grasp the edges and easily pull down, the plastic clamps will release and pop out). Feel around where the dome light hole is in the headliner and about an inch from the opening, towards the passengers side, you will feel wiring that is bundled with a grey foam at the end.
Easily pull the grey portion down. That unattached electrical connector is for the power rearview mirror on the BRZ and not used on the FRS. There are 3 wires (blue, black, grey). The middle black wire is the ground and the grey is the power and ONLY on when the ignition is on.
I used two small, blue, U shaped metal electrical connectors with half of the U cut off and stuck them in the back of the wiring harness (grey power, black ground), wrapped the connections some with electrical tape, then connected the hardwire kit that came with the V1. Secured all the wires so there was no rattle in the headliner. Reattached the dome light. This is just like using an invisicord.
Oh, you can feed the wire to the radar detector through the headliner towards the windshield, there is a small gap between the headliner and windshield.
Hope this helps. Doc.
Doc is offline   Reply With Quote
The Following 9 Users Say Thank You to Doc For This Useful Post:
avusblue (11-24-2012), BabaYaga (05-15-2015), bestwheelbase (11-25-2012), Caspeed (10-27-2014), cdo221 (01-09-2013), Freeman (11-24-2012), Ornelas66 (03-03-2015), Plxdjake89 (01-08-2013), tbrocato (11-25-2012)
Old 11-24-2012, 09:15 PM   #2
Carban
Grease Monkey
Carban's Avatar
Drives: Whiteout FR-S
Useful info. thanks.
R.I.P. '92 Honda Prelude you will be missed
Carban is offline   Reply With Quote
Old 11-24-2012, 09:34 PM   #3
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
I believe that there is already a DIY about this.
But if its different then this is good info.
Club 4AG | Apex'i | HKS | GrimmSpeed | TRD | Beat Sonic | ENKEI | Cusco | Fujitsubo
Originally Posted by Jyn View Post
That guy, like me after BBQ Thursdays, is full of shit.
Calidrifter is offline   Reply With Quote
Old 11-24-2012, 09:57 PM   #4
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Very useful, thanks
Freeman is offline   Reply With Quote
Old 11-25-2012, 03:38 PM   #5
Doc
Doc's Avatar
There is a DIY (thank you) for the BRZ to hardwire via the dome light by tapping into the rear-view mirror harness, but I didn't see one for the FRS. Even through the BRZ / FRS are twins, sometimes the wiring can be slightly different with twins.
I just wanted to share so that others know that the FRS does indeed have the rear-view mirror connector / harness, it is simply not used.
The Following 3 Users Say Thank You to Doc For This Useful Post:
avusblue (11-25-2012), calis5nest (05-18-2013), Freeman (11-25-2012)
Old 11-25-2012, 10:07 PM   #6
Dtronic
Dtronic's Avatar
Drives: 2013 Whiteout FRS
Thanks!
Going to try it this week.
Dtronic is offline   Reply With Quote
Old 11-25-2012, 11:40 PM   #7
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
Good info. Another DIY showed using the glove box's 12 volt connector as an option too.
Scaldy is offline   Reply With Quote
Old 11-25-2012, 11:46 PM   #8
tbrocato
Drives: 2013 Raven FR-S (MT)
thanks doc I will use this method instead of running into the glovebox.
tbrocato is offline   Reply With Quote
Old 11-25-2012, 11:48 PM   #9
Doc
Doc's Avatar
Yes, that is another viable option. But why run the wires if there is no need to? I didn't even test it, but is the glove box accessory plug a constant power source or only "hot" when the ignition is turned to ACC or ON?
I found it rather interesting that they choose the glove box as an accessory outlet location. I may tap into that location for the LED footwell / interior lighting.
Old 11-26-2012, 09:23 AM   #10
avusblue
avusblue's Avatar
Drives: 2013 FR-S, Manual, Argento
Doc, the glove box accessory plug is only "hot" when the ignition is turned to ACC or ON.
Thanks for figuring out the overhead wiring for us. While I have my Valentine One currently powered by the glove box accessory plug, I may re-do it using the dome light power as you have done. Just seems cleaner, and it would free up the glove box plug for other purposes (potentially, LED footwell lighting).
Cheers!
avusblue is offline   Reply With Quote
Old 11-26-2012, 11:28 AM   #11
zaptorque
zaptorque's Avatar
Drives: 2013 Asphalt FR-S
Are radar detectors even useful anymore since it seems like all cops are using laser now?
zaptorque is offline   Reply With Quote
The Following User Says Thank You to zaptorque For This Useful Post:
Maik L (11-26-2012)
Old 11-26-2012, 11:52 AM   #12
LIKEABOSS
LIKEABOSS's Avatar
Drives: 2013 Boss 302 & 2013 FR-S
Thanks for the info. This is on the to-do list.
LIKEABOSS is offline   Reply With Quote
Old 11-27-2012, 02:25 AM   #13
knaa
Drives: FRS
do you have any pics? those would help alot, i got a little confused halfway
knaa is offline   Reply With Quote
Old 11-27-2012, 11:32 AM   #14
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
It depends on the area. Where I live, radar is still widely used. Also, police cannot use ladar while moving, so they keep radar running in their cars to get the speed of the car in front and behind them. In that sense, it helps point out when a cop is coming up ahead, whether they are driving or not.
thejevans is offline   Reply With Quote
DIY-Replacing Rear View Mirror/Hardwire Radar Detector Lil Abner DIY (Do-It-Yourself) Guides 40 06-11-2020 03:48 PM
DIY: Hardwiring your radar detector speedracer38 DIY (Do-It-Yourself) Guides 108 09-08-2019 11:06 PM
BRZ hardwire radar. Jive Turkey DIY (Do-It-Yourself) Guides 12 03-20-2015 01:11 AM
Win a Laser/Radar detector! raul Off-Topic Lounge [WARNING: NO POLITICS] 0 10-10-2012 02:57 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 05:31 PM
