Drives: 2013 Firestorm FR-S
White line KCA434 front lower control arm bushings
Anyone installed these yet? The front lca bushing is a odd spherical bushing? that my mechanic says is prone to early failure in other cars he has seen. Figure these should improve the steering response as well.
Curious for feedback from anyone who is running them.
2013 Firestorm FR-S, MTX, build date 1/13.
#2 |
Just the tip
I'm running them but no track days on it yet. Only one autox session. I have all of the Whiteline bushings on and their sway bars as well. I didn't really notice much if anything with those bushings, but like I said I haven't been to the track. I have noticed a positive difference with their rear sub-frame inserts, differential inserts, and trans mount. My build thread has info on what I've done to my car if curious. I'm thinking those bushings wouldn't yield too much of a difference since the stock ones were brand new. If the stock ones were old and used up then I'm guessing I'd notice more of a difference with those bushings. Regardless my car feels very planted, stiff, and tight, insert other similar adjectives here...
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#3 |
AutoX-10/10ths every run
I've been running the bushings on my car for nearly 6 months. 12000+ miles, a dozen or more AutoX event days, NO issues.
#4 |
Drives: White 2013 FRS
I have them, feel great. I changed them with the WL castor bushings, rear upper control arm bushings and steering rack bushings.. so all a contributing factors for the better feel. But as others have said, the difference won't be so great as you arecoming from fresh factory bushings that have yet to break in.
#5 |
I'm getting ready to install the KCA434's on the front LCAs later this week (rented a bushing press kit) and I'm curious, for those that installed them, does the urethane bushing rotate in the stainless housing? (I haven't received them yet).
I know you need to orient the dimples towards the inside of the car per the whiteline instructions but I'm worried about the precision of the alignment of the dimples.
| The Following User Says Thank You to brillo For This Useful Post: | s0sl0w (08-02-2015) |
#6 |
Proud of Boxer
I would also like an answer to this question.
#7 |
Drives: 2014 Toyota GT86
No ! I was try to adjust it but couldn't , not without taken the arm off. But mine is super pro , look very similar to whilteline .
| SPC Lower Control Arms(Old and New) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 79 | 07-10-2017 10:58 PM |
| ROBISPEC Front ADJUSTABLE tubular lower control arms | robispec | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 75 | 04-05-2015 10:36 AM |
| WTB: FRONT LOWER CONTROL ARM (PASSENGER SIDE) | Filipino Royale | Brakes, Suspension, Chassis | 0 | 04-20-2013 07:38 PM |
| Front Control Arm Bushings. | feldy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-02-2013 06:35 AM |
