Old 07-03-2012, 07:28 PM   #1
DrakeM
Drives: Researching the BRZ
BRZ ‘s “boomerang” LED strip mystery
When exactly does it come on? Is it designed to work in conjunction with the HID lamp only?
Can it be used as a DRL (day running light), with or without the specific DRL lights?
I’d love to see a pic with just the DRL and the LED strip simultaneously lit. Anybody?
DrakeM is offline   Reply With Quote
The Following 2 Users Say Thank You to DrakeM For This Useful Post:
86design (07-03-2012), radroach (06-24-2013)
Old 07-03-2012, 07:29 PM   #2
thermobox
Drives: 16 Impreza 5dr CWP
These will both be lit when you have the light selector in Parking Lights.
Per the Owners Manual:
O = Off - The daytime running lights turn on.
AUTO - The headlights, parking, daytime running lights and so on turn on and off automatically. (Vehicles without a keyless access with push button start system: When the engineswitch is in the "ON" position.
Vehicles with a keyless access with push-button start system: When the push-button ignition switch is in "ON" mode.)
Parking Lights - The side marker, parking, tail, license plate, daytime running lights and instrument panel lights turn on.
Headlights - The head lights and all the lights listed above (except daytime running lights) turn on.
thermobox is offline   Reply With Quote
The Following User Says Thank You to thermobox For This Useful Post:
gmookher (12-04-2012)
Old 07-03-2012, 07:31 PM   #3
DrakeM
You mean the regular DRL’s and the LED’s?
Old 07-03-2012, 07:50 PM   #4
Innova
Drives: 2013 BRZ Limited
You can run just that and the DRL LED strip by selecting the option one click above "auto" - it looks pretty awesome but the interior will dim.
Innova is offline   Reply With Quote
Old 07-03-2012, 07:52 PM   #5
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Isnt that the parking light setting?
No lie, I've been driving around with them on just because
First car I've owned that looks badass and I cant help it!
Kido1986 is offline   Reply With Quote
The Following 11 Users Say Thank You to Kido1986 For This Useful Post:
86design (07-03-2012), davtbaum (06-25-2013), enwave (07-08-2013), jbsali (01-17-2014), Kinickie (06-25-2013), racecaresuaceb (05-16-2013), redKnight (07-11-2013), spdfreak (06-25-2013), speedracer38 (07-04-2012), tripjammer (07-06-2012), WRXGuy1 (07-05-2012)
Old 07-03-2012, 07:54 PM   #6
DSPographer
DSPographer's Avatar
Drives: '13 BRZ Lmtd
The "boomerang" lights come on with the headlights and with the switch set for parking lights. The much brighter 3 LED strip running lights above the fog lights come on whenever the car is running and the hand brake is off and the HID headlights are off. When driving with the switch in the parking lights setting the running lights, boomerang lights, side markers above the wheels, tail lights, and marker plate light will be on.
Last edited by DSPographer; 07-03-2012 at 08:51 PM. Reason: Corrected for running lights off when HID are on.
DSPographer is offline   Reply With Quote
Old 07-03-2012, 08:20 PM   #7
DrakeM
I’m starting to understand (my bad for not properly explaining this from the beginning)
So I could drive with both the “boomerang” and the dedicated day running lights, but only if the regular and the side markers are also on?
In other words, there is no way to drive with just the boomerangs and the DRL’s? Just the two, and no other lights?
Old 07-03-2012, 08:24 PM   #8
DSPographer
Right, the HID headlights will not be on since you use the parking light position to turn on the "boomerangs" with the running lights, but the rest of the lights that come on with the parking lights will be on.
Old 07-03-2012, 08:25 PM   #9
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
"regular"?
Parking lights setting will give you boomerang, led strip, side marker, and rear lights on.
If you turn your headlights on, it seems the led strip (DRL) turn off!
Fog lights only come on if you have your headlights on - though there will likely be a work around DIY mod to change that if you want them on with parking lights.
ashtray is offline   Reply With Quote
Old 07-03-2012, 08:43 PM   #10
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
I switch it to parking mode when it is overcast. Seems like the headlights don't turn on until it's really dark so I use the halos for the in between times (too dark to read the gauges but not dark enough to need headlights). I don't think they're bright enough to see in full daylight and I don't like having the interior dimmed during the day so I don't bother with them when it's sunny out. I have yet to turn on the fog lights other than to test them out when I first got the car. I couldn't tell any difference with them on or off.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
The Following User Says Thank You to Spaceywilly For This Useful Post:
Marchy (05-17-2013)
Old 07-03-2012, 08:59 PM   #11
DSPographer
Originally Posted by ashtray View Post
"regular"?
Right
I think this is the way OEM fog lights normally work. I think glare from low-beams in the fog can be reduced by using the leveling adjustment to point them down. So, there may not be a need to make the mod to turn them on with the parking lights.
Old 07-03-2012, 09:03 PM   #12
xcelir8brz
Working on independent fog light mod. Trying to do it without major rewiring.
xcelir8brz is offline   Reply With Quote
The Following 2 Users Say Thank You to xcelir8brz For This Useful Post:
Exhaust (07-03-2012), R0ME0 (12-06-2012)
Old 07-03-2012, 09:18 PM   #13
OrbitalEllipses
Drives: Attitude
It is. Only comes on when headlights are on, fog switch is engaged, and high beams are off.
On my WRX I had them wired to run from the switch independently of headlights as my DRLs, which I disabled.
Old 07-03-2012, 09:24 PM   #14
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
I was disappointed by how dim the boomerangs are, especially off axis. The DRL strip likely will overpower it.
I am hoping to find a way to toggle the DRL's manually.
MmmHamSandwich is offline   Reply With Quote
no front LED strip? Lydin Scion FR-S / Toyota 86 GT86 General Forum 3 06-03-2012 03:05 AM
FR-S SNS 200 mystery NAV/XM/Receiver FR-S-Ohio Electronics | Audio | NAV | Infotainment 2 05-31-2012 07:58 AM
About the LED strip on the GT86 Sasquachulator Scion FR-S / Toyota 86 GT86 General Forum 14 05-15-2012 01:14 AM
Mystery Clay Model From Toyota Video Dark Other Vehicles & General Automotive Discussions 16 02-18-2011 05:21 PM
