Old 03-18-2015, 10:02 AM   #1
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
BRZ shift gear indicator wants you to shift gears too soon?
I have set up my BRZ to show me which gear am i when driving. Im sure that you guys have notice that small up arrow that blinks to you can shift gears, i guess this is done to maximize fuel economy.
However i feel like the up arrow wants me to shift too soon. For example as soon as the tac is getting closer to 2k rpm the up arrow blinks asking to change gears...
So sometimes, i can be in like 6th gear and only by at 40mph... Im not sure if its right or wrong for the engine/transmission..
Do you guys think that that up arrow wants you to shift too soon? If not what is you average rpm before shifting to next gear?
Jfheisenberg is offline   Reply With Quote
Old 03-18-2015, 10:11 AM   #2
ThreeFive
Drives: 2013 BRZ LTD Black
Hmm... I don't know too much but when I was taught to drive manual, I was informed that shifting between 2-2.5k rpm is the most efficient. That's how I usually shifted in my BMW before getting the BRZ so I never thought too much of it.
ThreeFive is offline   Reply With Quote
Old 03-18-2015, 10:17 AM   #3
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
That little arrow wants to maximize efficiency, so it may encourage you to shift earlier than you typically would. That should generally be fine as long as you're not going up a hill or in some other scenario that would cause the engine to bog down.
Anecdotal evidence, but I did notice an average MPG increase when I started making a conscious effort to shift when it tells me to (when I'm not hooning, of course).
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 03-18-2015, 10:36 AM   #4
jdmblood
jdmblood's Avatar
Drives: white subaru brz
just redline each gear...
jdmblood is offline   Reply With Quote
The Following 7 Users Say Thank You to jdmblood For This Useful Post:
calmtigers (03-19-2015), funwheeldrive (03-18-2015), GhostRai (03-20-2015), jsalaz03 (12-28-2015), nick_318is (03-18-2015), scottxnizzle (03-18-2015), sftateofmind (03-25-2015)
Old 03-18-2015, 10:45 AM   #5
MrBlaze-65
Drives: 2014 Subaru BRZ
As codesplice mentioned this is a efficiency shift light. It's trying to help you get the best MPG. Like always with driving a car use your best judgement. If your RPM's are low and you need to get over a lane in front of someone you won't be in the best position to do so. Their will be times when that suggested RPM level is lower then what you want to be in.
MrBlaze-65 is offline   Reply With Quote
Old 03-18-2015, 10:46 AM   #6
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Honestly, do people actually use this function? This was the first thing I disabled.
Just play it by ear folks.
Jesse36m3 is offline   Reply With Quote
The Following User Says Thank You to Jesse36m3 For This Useful Post:
Koa (03-18-2015)
Old 03-18-2015, 10:47 AM   #7
Rabbit of Caerbonnog
Run Away!
Rabbit of Caerbonnog's Avatar
Drives: 2015 Subaru BRZ Limited
This video might help.
[ame="https://www.youtube.com/watch?v=fB9dcC9dl3w"]Scion FR-S: How to set the Shift Light & Gear Indicator Display Settings (BRZ GT86) - YouTube[/ame]
Rabbit of Caerbonnog is offline   Reply With Quote
Old 03-18-2015, 10:59 AM   #8
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
The arrow doesn't usually light up until you're at a speed where you won't bog the next gear. If the computer senses you're going up a hill or accelerating, it shouldn't light up the arrow (at least I haven't seen it)
daiheadjai is offline   Reply With Quote
Old 03-18-2015, 11:02 AM   #9
navanodd
Drives: 2013 BRZ Sport-tech WRB
So in the manual the arrow is for efficiency? I would have assumed it worked like the arrow in the auto did. If I have no arrow, it means that a shift would put the engine below idle speed and in the auto it just won't do the shift.
navanodd is offline   Reply With Quote
Old 03-18-2015, 12:38 PM   #10
Guillaume
Guillaume's Avatar
Drives: Exige S 240
We're not talking about the adjustable shift light/bip here. We're talking the small arrow near the gear indicator.
Guillaume is offline   Reply With Quote
Old 03-18-2015, 12:43 PM   #11
berkbrzfan
Drives: WRB BRZ
If you are going to follow the arrow for gear changes, you will be driving the car like it was not meant to be. The arrows are meant to keep you rolling along smoothly with the best efficiency.
I tried it during the break in period. Very soon you will feel the car asking you to ignore it. Try it if you want the experience. You will not stick on to using it for long. Or you could just let it blink as you smile and rev all the way through it!
berkbrzfan is offline   Reply With Quote
The Following User Says Thank You to berkbrzfan For This Useful Post:
Jfheisenberg (03-18-2015)
Old 03-18-2015, 01:05 PM   #12
Jesse36m3
Jesse36m3's Avatar
I know this .. You can disable the gear indicator entirely on the brz limited by scrolling through a few options and selecting "G-OFF", which also disables the shift up indicator. No need for that crap.
Old 03-18-2015, 01:20 PM   #13
CBR600RR
Drives: Raven Black
I find that if I fallow that arrow when accelerating, eventually it will put me in 6th too soon and the engine will bog
Old 03-18-2015, 01:22 PM   #14
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Ya I know wut u mean, a lot time I see it wants me to shift at like 2k rpm so i will end up sitting at 1.5k rpm at next gear. Usually i just ignore it....... and rev it till at least 2500.
I don't feel our car like anything below 2k unless u are in 1st gear.
*ON the side note, the timing of rev indicator changes with ur driving habbit too.
Hearing a squeak whenever I accelerate and shift gears slowbrz Issues | Warranty | Recalls / TSB 7 05-29-2022 09:52 PM
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 09:42 PM
shift indicator sticker Juurian Cosmetic Modification (Interior/Exterior/Lighting) 27 05-25-2013 02:03 AM
Shift position Indicator Ryan86 AFRICA 17 04-12-2013 08:24 AM
what does the rpm shift indicator beep sound like? pr086 Scion FR-S / Toyota 86 GT86 General Forum 10 07-26-2012 02:28 AM
