Drives: 2013 Scion FR-S 6MT Raven
Why is it so important to cut the bump stops when lowering my frs?
I installed the tein s tech springs on my FRS and low and behold i forgot to cut the bump stops. What is the purpose of cutting my bump stops? and is it a major step?
A.Corvino
http://www.streetmasters.com/ |
#2 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Did you buy the tein's second hand? I would have thought the kit would have supplied replacement stops.
#3 |
Short answer: They are bump stops. Less spring + more bump stop = big bumps
#4 |
Drives: RAVEN
Because when the car is going around a corner and it hits a big bump it is going to jump when it hits the bump-stop hard. This causes the tire to lose traction, the car to snap around in sudden over-steer (or under-steer if on front) and you will die a horrible death taking all your passengers with you.
Picture it this way, you and your buddy Springbob are having a push and shove match. You are equally matched and with a little give and take. Then your other friend Bumpbob, weighing like 1000 lbs and moving very fast, suddenly rams into the back of Springbob. You pretty much lose your footing and go for a loop on your ass. That is what happens to your tire and its traction. So, like not a big deal. |
#5 | |
#6 |
Except it's not that bad. It effectively raises the spring rate, but it's not like hitting a wall.
| Does anyone have their OEM bump stops that they're not using? | CSG Mike | Tracking / Autocross / HPDE / Drifting | 2 | 08-05-2014 09:02 PM |
| FS: Like new Tein S-Tech lowering springs -1.4" Drop w/ Custom Bump Stops | STS-V | Brakes, Suspension, Chassis | 6 | 07-31-2014 07:43 AM |
| SWIFT Spec R Springs - Bump stops | project d | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 05-03-2014 08:25 PM |
| Lowering springs and bump stops survey | solidONE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-27-2013 11:23 PM |
| Swift Springs: Cut OEM Bump Stops? | BillY2KFRC | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 03-22-2013 01:45 PM |
