| Software Tuning Discuss all software tuning topics. |
Drives: 2013 WRB BRZ Limited
OFT V4.0x Flash Dyno Results
I thought I'd post this here incase anyone was curious on the results.
2013 BRZ 6 Speed 56,000 Miles Performance Mods: Tomei UEL Headers Motiv Overpipe Motiv Front Pipe with High Flow Catalytic Converter Perrin 2.5" Resonated Catback Open Flash Tuner (OFT) with stage 2+ 4.0x Tune 93 Octane Gas Supertek Intake Inlet w/ K&N Filter 184hp/148trq to the wheels -B Graph 1 = Stage 2+ v4.0x with mods Graph 2 = Stock Tune with Perrin Catback/Intake vs. Stage 2+ v4.0x with mods [ame]https://www.youtube.com/watch?v=ddpEoUDuFkk[/ame] Last edited by HeresMyMind; 10-05-2018 at 09:28 AM. |
| The Following 4 Users Say Thank You to HeresMyMind For This Useful Post: |
#2 |
Drives: 2017 manual BRZ
184 on a heartbreaker very nice. Thanks for the post! Have any e85 to play with where you're located?
Sent from my Pixel 2 XL using Tapatalk |
#3 |
#4 |
Drives: 2017 WRB M/T BRZ
@HeresMyMind is that a standard/non-modified OFT stage 2+ 4.03 off-the-shelf ROM?
Torque Dip is completely gone, replaced by small bump at around 4500 RPM! |
#5 |
Very nice TQ curve. I plan to get my car done on 91 and e85. Modified tunes done by a member based on the v4 oft base tunes.
2013 Series 10 FRS #553
#6 | |
The run was also after the IAM got up to 1.0 after a few light pulls. My mods just Happened to be the perfect combo for this flash. I may be able to squeeze a tint bit more power by leaning it out to 12.5 afr average but the 11.9-12 is more on the safer end. Especially for a generic map. -B |
| The Following 3 Users Say Thank You to HeresMyMind For This Useful Post: |
#7 |
Drives: brz 2017 hksv2
or you could try rising a bit the timing without leaning the afr, timings on v4 are not sooo extreme
#8 |
#9 |
you could do that in few minutes with romraider
just few logs to see if it knocks, if all goes well you could have a bit more power and better fuel economy
| The Following User Says Thank You to tomm.brz For This Useful Post: | HeresMyMind (10-01-2018) |
#10 | |
Drives: 2017 toyota 86
Also +1 for doing a ecutek comparison. i have a custom oft tune, but have been thinking about getting a custom dyno ecutek tune. |
#11 |
| The Following 2 Users Say Thank You to HeresMyMind For This Useful Post: | 86TOYO2k17 (10-01-2018), Teseo (10-01-2018) |
#12 |
Drives: 2013 FR-S Argento
Wow very nice - just a quick and dirty comparison, torque gains around 20% in the 3000's. Then around 10% average between 4000 and 6000. And then great gains on the top end, peak gain of about 24% near redline. All with a 'canned' tune.
But wait, this can't be right. I just read on here that the only good header out there was the $1400 ACE? Everything else was crap with torque dips.
| The Following User Says Thank You to bfrank1972 For This Useful Post: | jflogerzi (10-01-2018) |
#13 | |
Most EL headers still have the torque issue. The only one I've seen that has a flat trq value are HKS EL's. Although I dont think they have the best overall gains. Check out these results. -B |
#14 |
All UEL comparisons
-B |
| My Nameless header dyno results (results to follow) | Simply_the_best | Engine, Exhaust, Transmission | 39 | 06-28-2016 05:09 PM |
| Australian Dyno Dyno Results | Shiv@Openflash | Software Tuning | 11 | 07-22-2015 05:57 AM |
| Baseline Dyno Results | JJJ | Engine, Exhaust, Transmission | 2 | 06-23-2015 07:49 PM |
| 86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 07:54 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
