Old 11-29-2014, 09:43 PM   #1
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
Exhaust leak?
I recently installed the nameless EL headers with my Op/fp combo. This is my first catless header. It's a little tinny from 1500 to 3500 rpms and I think there may be an exhaust leak. I definitely can't see one and have spent 3 or 4 times laying under the car with it running. Is there a way to test it? I see 2 or 3 threads talking about a "smoke test"? I also have an OFT heading my way...
Jman1759 is offline   Reply With Quote
Old 11-29-2014, 09:49 PM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I don't know if this will help you much or not, but if you can have a friend, significant other, small child with basic motor function, etc... you can put a rag or work glove over the tailpipe (essentially blocking the exhaust gas's only way out) and see if you can hear the leak. Have a look at this video:
[ame="https://www.youtube.com/watch?v=wYVjkyLdID4"]How to Find Exhaust Leaks - EricTheCarGuy - YouTube[/ame]
Also, I THINK, don't know for sure, that aftermarket headers have a different sound to them due to them being made of tubing and not cast iron.
Bobblehead is offline   Reply With Quote
Old 11-29-2014, 10:51 PM   #3
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
Do you feel that your accel pedal isn't as responsive? If you do have a leak its probably at the gasket somewhere, if its really small it'll be difficult to locate. When the OFT does come, log for fuel trims and if the Long-term Fuel Trims is really off like > +-6%, probably means yeah... good luck!
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Old 11-29-2014, 11:07 PM   #4
Jman1759
Builder
No, I don't feel any reduced responsiveness, good info on the OFT, thanks.
Old 11-29-2014, 11:11 PM   #5
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Exhaust leak?
Headers sound raspy at times, make sure you're not confusing the two. Also for really cheap you could purchase a car's stethoscope that allows you tap and listen to any place you may think you have a leak. The stethoscope magnifies the leak sound making it sound like it hurricane in your ears.
Costs $19 really handy when dealing with exhaust components.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Fixing a pernicious exhaust leak (help!) SirBrass Engine, Exhaust, Transmission 32 07-22-2014 09:22 PM
Exhaust Leak help? ray7792 Engine, Exhaust, Transmission 4 07-04-2014 01:08 PM
Exhaust leak. J8boston8j Engine, Exhaust, Transmission 17 10-15-2013 08:09 PM
Greddy SP Elite exhaust leak qijian Engine, Exhaust, Transmission 1 10-06-2013 06:04 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 12:59 PM
