Old 11-09-2011, 01:56 PM   #1
f1ver
Drives: lexus gs300
h6 swapouts? any thoughts or advice?
was looking at some stories and videos of people who had swapped out their impreza/legacy/STI engines with h6 engines... would something like that be possible for the BRZ? think it would it be a better car, or just jack up the handling? how much does something like that cost, and is it hard to find someone who can be trusted for reliable work?
thx
f1ver is offline   Reply With Quote
Old 11-09-2011, 02:01 PM   #2
mikey
Drives: 2006 Subaru WRX STi
probably. but if you decide to do this, be prepared to spend A LOT of money, and dont expect your car to be returned to you in a short amount of time.
the car hasnt even hit the market, so nobody except for toyo and suba engineers really know what the engine bay looks like...
mikey is offline   Reply With Quote
Old 11-09-2011, 02:09 PM   #3
bFreed
bFreed's Avatar
Drives: FRS, X83, W108
Anything is possible for the right amount $$$$$$
bFreed is offline   Reply With Quote
Old 11-09-2011, 02:18 PM   #4
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
You'd end up adding a bunch of weight in front of the front axle. So yes, the handling would be screwed. I hate to suggest this, but a turbo kit would be an easier/smarter/more viable solution for moar powah.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 11-09-2011, 02:27 PM   #5
fatoni
if thats what you want i would suggest saving time and money and just get a 911
Old 11-09-2011, 03:07 PM   #6
old greg
Rocket Surgeon
Drives: PSM GGA OMG
The EZ30R (the R is important) and EZ36R both weigh ~50 lbs more than a DOHC EJ, so I doubt the handling would be effected all that much. The H6 engines aren't particularly expensive, you can find EZ30R's in the $1500 range if you look hard enough. Very few people bother swapping them into Imprezas, so there isn't a lot of demand driving up the price. The big downside is that the OEM H6 ECU has some sort of anti-theft feature that makes it a worthless brick, so you'll need to buy/install/tune a stand alone ECU.
If you have the tools and don't mind doing your own wiring/tuning, you could probably swap one in for < $3000. If you sell your stock motor, you might even come out ahead. Getting more than ~270 bhp out of one, though, is going to burn a crater in your wallet.
old greg is offline   Reply With Quote
Old 11-09-2011, 04:27 PM   #7
Dimman
Kuruma Otaku
Dimman's Avatar
The 'R' means it doesn't have the absurd single exhaust port per head, correct?
Because titanium.
Old 11-09-2011, 04:45 PM   #8
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Yes, you are correct. Although, in the EZ30D's defence, that single exhaust port makes custom headers super easy.
Old 11-09-2011, 05:04 PM   #9
coyote
coyote's Avatar
Drives: Slowly
Technically speaking, I think you'll find they are both EZ30D.
coyote is offline   Reply With Quote
Old 11-09-2011, 05:10 PM   #10
Syldrin
Troll Feeder
Syldrin's Avatar
Drives: boosted scion tc.
i hope this statment is true but with 12.5:1 comp ratio i don't know how viable boost will be on this car.
Syldrin is offline   Reply With Quote
Old 11-09-2011, 07:58 PM   #11
Kostamojen
IMO, the 6-cylinders are a better option than the Turbos. You won't have to figure out where to put the turbo and deal with all the custom piping, and considering how far back the engine is in the FT86 chassis it should fit in there even better than they do in the Imprezas!
I wouldn't be surprised if we see one or two H6 swaps showing up next year, maybe at SEMA or another venue.
Ya, but one motor is so different than the other people just started calling it the EZ30R (along with how they called the cars 3.0R and such).
Old 11-09-2011, 08:08 PM   #12
fred_boosted
fred_boosted's Avatar
Drives: 2008 EVO X GSR (Sold)
ECU, trans, diff...
I'm sure it will have LS3 swap in the future...
I could get Maserati Quattroporte or BMW M3/M6.
But I gived up.
Why? Because thats just not my style.
fred_boosted is offline   Reply With Quote
Old 11-09-2011, 08:11 PM   #13
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
I will bet dollars to doughnuts that a turbo install will be way easier than any EZ swap, there are only a handful of impreza's running with legit setups. I've talked to Chris at EFI Logics who built one of the greatest track H6 imprezas and he told me that it would be more time, money, and issues; all for less power.
And if you goal is high power than the EZ's will submit defeat to the EJ's without a doubt.
chulooz is offline   Reply With Quote
Old 11-09-2011, 09:10 PM   #14
Kostamojen
There are only a handful because of how easy it is to swap the turbo motors instead. Plus, nobody has done the work on the H6 ECU's (well some have, but usually winds up being a stand alone setup) and its more complicated to fit the H6 into the Impreza engine bays as it takes a bit of work to get them to fit.
With the Toyobaru's drivetrain location being where it is, I don't see how the EJ turbo setup will fit as it currently exists. There won't be enough room behind the motor, and there won't be enough room under the motor. Its going to require some sort of custom turbo location, which is more difficult than making the H6 fit.
Aspera's thoughts on AWD/RWD... aspera Scion FR-S / Toyota 86 GT86 General Forum 89 11-16-2013 03:55 PM
Your thoughts of the Ford Mustang Abflug Other Vehicles & General Automotive Discussions 31 08-25-2011 11:15 AM
Thoughts and secrets of the FR-S/FT-86 Interior KevinDuMa Scion FR-S / Toyota 86 GT86 General Forum 56 07-21-2011 03:38 PM
Thoughts on the auto show? R_E_L Southern California 3 11-30-2010 03:23 PM
what are your thoughts on rota wheels? VenomRush Other Vehicles & General Automotive Discussions 46 11-24-2009 04:08 AM
