Old 12-03-2014, 04:15 PM   #1
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Undertray Bolts Part #'s and/or sizes
So I noticed the shop that installed my RevWorks UEL header decided they'd reinstall the undertray with only ONE freaking bolt; I'm missing 11 of the 12 bolts for the metal undertray (but still have the plastic push-pin style clips).
Does anyone know the part # for these bolts, if they sell them as a OEM hardware kit, or the sizes and counts for each type of bolt? (I think there are 2 or 3 different sizes)
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 12-03-2014, 04:43 PM   #2
Koa
Did you bring this to your shop's attention?
sorry to not answer your question but that's the question I think a lot of us will have
Old 12-03-2014, 04:49 PM   #3
smbstyle
smbstyle's Avatar
Yes.
2013 SWP BRZ
Old 12-03-2014, 05:16 PM   #4
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
step 1 return to shop. step 2 demand your bolts back.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 12-03-2014, 05:32 PM   #5
WOODNUTS_86
WOODNUTS_86's Avatar
Drives: 2014 Scion FR-S; ashpalt grey
HEY THERE I WORK IN A PARTS DEPARTMENT AT TOYOTA IN CANADA IF YOU COULD SEND ME A PIC I COULD LOOK INTO A PART # FOR YOU.. ISSUE IS CANADA'S PART NUMBERS MAY BE DIFFERENT THAN AMERICAN NUMBERS
WOODNUTS_86 is offline   Reply With Quote
Old 12-03-2014, 05:32 PM   #6
smbstyle
smbstyle's Avatar
Boy ya'll sure are helpful. They don't have the bolts. The purpose of this thread wasn't to find out how to ask a shop for bolts, I'm asking for part numbers and/or sizes.
Now, moving on....
2013 SWP BRZ
Old 12-03-2014, 05:39 PM   #7
Koa
Now, moving on....
Why don't you ask them to furnish you bolts?
I'd be pretty furious. If they fucked up that hardcore installing your cover, imagine what they did while installing the header.
Now... onto teaching you how to use parts catalogs.
Try and find your bolt here man.
Should be #28 or #29. We may be helpful, but typically not to people who are being lazy
http://www.subarupartsamerica.com/pa...ODY%20HARDWARE
Old 12-03-2014, 05:53 PM   #8
smbstyle
smbstyle's Avatar
So for anyone interested, here are the part #s:
901000413 Qty: 8 Flange bolt M8x16
010006167 Qty: 4 Flange bolt-pilot
2013 SWP BRZ
The Following 2 Users Say Thank You to smbstyle For This Useful Post:
ser1alchill3r (10-12-2020), Viper8 (05-18-2019)
Old 12-03-2014, 05:57 PM   #9
smbstyle
smbstyle's Avatar
I did, they don't have them, which is why I was trying to locate the bolt part #'s on here.
Never used that site, thanks for the help. Not sure how asking for help on the forum is being lazy, as I already did a cursory search and couldn't find them? Ended up with a friend who's a service manager tracking them down.
2013 SWP BRZ
Old 12-03-2014, 07:07 PM   #10
Koa
Apologize for coming off crass- parts catalogs have saved my ass a handful of times. Service dept friends even moreso!
The Following User Says Thank You to Koa For This Useful Post:
smbstyle (12-04-2014)
Old 12-03-2014, 07:52 PM   #11
kchar
Because Racecar
kchar's Avatar
Well I don't know the part numbers but I know that there are 4 smaller bolts which go on the rear side of the tray and the rest are the same size. I want to say the bigger bolts are 14mm and the smaller are 12mm. I'm sure someone on here could verify.
Also there's 3 big pop clips on each side in the middle section of the tray. There are a handful more areas for the big pop clips ( <5 ) and a couple for the small pop clips. If you just by a bunch you'll be able to figure it out by trial and error cause that's what I have to do every time I'm putting it back on ha
kchar is offline   Reply With Quote
Old 12-04-2014, 08:59 AM   #12
smbstyle
smbstyle's Avatar
Thanks, yeah the pop clips look to be present.
I believe these bolts 010006167 (qty: 4) are the ones along the rear side of the tray that connects the panel underneath the trans with the vent.
2013 SWP BRZ
Old 03-15-2017, 08:55 PM   #13
kinchu007
Drives: Ghost BRZ
THANK YOU!!
kinchu007 is offline   Reply With Quote
Undertray rattling Tainen Issues | Warranty | Recalls / TSB 2 09-29-2014 10:27 PM
Drain plug gasket: Same part # different sizes? makalaka Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 04-28-2014 09:39 PM
Got hit (bumped)! Need part number for the black part of bumper. scottsampaio.com Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-25-2014 01:05 AM
Window Regulator Mounting Bolts - Noise Issue & Part Revision? PollosHermanos Issues | Warranty | Recalls / TSB 1 03-06-2014 11:39 AM
Part Number for OEM crash (camber) bolts for FR-S? Rampage Tracking / Autocross / HPDE / Drifting 4 07-11-2013 12:14 AM
