Old 10-26-2014, 05:51 PM   #1
aristo
aristo's Avatar
Drives: BRZ SWP 14
Cold start rattle after header,op,fp installed by a newb
Couldn't think of a proper thread to ask but just looking for a quick answer from the experts --
I installed the OFH, Motiv OP and Berk catted FP yesterday and upon starting up the car made a sound sort of like something was rattling?
Actually driving it after the cold start warm up doesn't seem to have any strange noises, both high rev and low
Would appreciate if anyone gave it a listen and chime in if it's 'normal' or within expected range or not. Catback is stock*
I'm also worried about mini exhaust leaks due to my first time installing this sort of thing but will save the check up for next weekend
Here is a video of the start up(lower volume a little it can be loud): for reference, iPhone used to record and was sitting on ground approximately 3 feet away from exhaust tips
[ame="https://www.youtube.com/watch?v=1Bp146e2HrM"]FR-S BRZ GT86 Open Flash Header + Motiv Overpipe + Berk HFC Frontpipe + Stock Catback - YouTube[/ame]
I found another video of someone with the Borla UEL (stock exhaust) cold start for comparison:
[ame="https://www.youtube.com/watch?v=7ZM5d_7c5Xo"]Borla UEL headers with stock exhaust - YouTube[/ame]
aristo is offline   Reply With Quote
Old 10-26-2014, 06:02 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Sounds like rasp, but you shouldn't with a catted FP...
The Following User Says Thank You to cdrazic93 For This Useful Post:
aristo (10-28-2014)
Old 10-27-2014, 12:13 PM   #3
jflogerzi
jflogerzi's Avatar
Was there clearance with the op and sub frame?
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
aristo (10-28-2014)
Old 10-27-2014, 12:29 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
Sounds like something's hitting something. Check clearances - there's not a lot of room I've noticed.
The Following User Says Thank You to Foobar For This Useful Post:
aristo (10-28-2014)
Old 10-27-2014, 02:27 PM   #5
aristo
aristo's Avatar
Drives: BRZ SWP 14
There is very little clearance between the subframe / swaybar and OP --- maybe a little less than half centimeter -- but when Installing everything I wiggled it around and there didn't seem to be a way to get any more clearance
I guess I am just going to jack the car up again and run under it to see if anything is shaking at start lol
Old 10-28-2014, 08:28 AM   #6
jdubious
Drives: 13 Scion FR-S
It could be the cat if its damaged, or defective. I would try to get up under there when its cold and tap on the exhaust with a rubber mallet or something to try to duplicate the noise.
jdubious is offline   Reply With Quote
The Following User Says Thank You to jdubious For This Useful Post:
aristo (10-28-2014)
Exhaust rattle on cold start? Laurie Scion FR-S / Toyota 86 GT86 General Forum 8 12-04-2020 08:15 PM
Rattle sound on cold start Frs32907 Issues | Warranty | Recalls / TSB 0 07-12-2014 11:36 AM
rattle sound cold start marky Issues | Warranty | Recalls / TSB 1 03-24-2014 07:16 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
Exhaust vibration/rattle at cold start? Foobar Engine, Exhaust, Transmission 7 04-16-2013 06:15 PM
