Old 08-27-2014, 11:08 PM   #1
bobsacamenoh
Drives: 2014 Scion FRS
Tap Flasher Install
Trying to get the OEM flasher disconnected. I was trying to pry it off the clip, but can't get it to come off. I saw a video telling the installer to put a flathead screwdriver into the slot at the top, but do I need to pry hard? I don't want to break anything as far as the mount goes.
Thanks
bobsacamenoh is offline   Reply With Quote
Old 08-27-2014, 11:09 PM   #2
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I just left my stock one in lol. I couldn't get it out. Ziptied the other up there.
post_break is offline   Reply With Quote
Old 08-27-2014, 11:17 PM   #3
Burrcold
Drives: Subaru BRZ Limited
Pry, pry and pry some more. Make sure to get hands nice and bloody! That's how I did it any ways.
Old 08-28-2014, 12:09 AM   #4
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
can't remember how I did it, but I just used the factory flathead screwdriver and was able to get it out. I believe the flathead is required to disengage a tab, or something... can't really remember. good luck though.
fwiw, I reclined the seat all the way, and was laying upside-down w/ my head in the footwell w/ a flashlight strapped to my head to do the install...
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 08-28-2014, 12:43 AM   #5
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
Thanks
I just used a tiny straight interior removal tool. you just need to lift the tab a little bit. Also, it is much easier if you pull the relay down first, then you can actually see it. You can see where the tab releases by looking at the replacement one also.
Jman1759 is offline   Reply With Quote
LED Flasher 6spd Exterior Parts (Aero, Lighting, Etc.) 2 08-08-2014 12:19 PM
Flasher problem after Valenti tail light install! czechm8 Cosmetic Modification (Interior/Exterior/Lighting) 10 06-27-2014 01:00 AM
DIY Tapturn Flasher Install with Strobe Option KAR DIY (Do-It-Yourself) Guides 23 06-14-2014 01:29 AM
Buddy Club Flasher Install Help kalamitykode Cosmetic Modification (Interior/Exterior/Lighting) 4 05-16-2014 12:28 AM
WTB: OEM Flasher Relay CanibeatNoel Audio/Visual, Electronics, Infotainment, NAV 2 05-01-2013 03:58 PM
