Old 11-18-2013, 10:43 AM   #1
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
Engine swap JDM EJ25 STI engine
I am thinking this engine could fit in with the stock mounts. I havent found much information. I think its a good topic to be discussed and wont be too expensive to do if you find a good used engine supplied with the turbo.
Mr Gushi has a similar ej25 engine in his car. It would be nice if we could narrow down year and perhaps part numbers. In case someone wants to order from Japan.
FRSToyota86 is offline   Reply With Quote
Old 11-18-2013, 01:21 PM   #2
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Ken Gushi and Toshiki Yoshioka both use EJs. Only seen pics of Gushi's and all I could notice was the cosworth intake manifold. Yoshioka uses a tomei genesis.
Its not impossible by any means but those guys have race team budgets. If you have money then ok.
There is also the debate that the FA is a better engine. I'm going to wager this thread will turn into an argument about that, the last one did lol.
Edit: I think the mounts are a tad different anyway
EvilBeaverFace is offline   Reply With Quote
Old 11-18-2013, 02:13 PM   #3
FRSToyota86
I guess you are right the FA is a newer engine after all but its only a 2lt.
Old 11-18-2013, 02:18 PM   #4
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
displacement isnt everything
Old 11-18-2013, 02:20 PM   #5
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
There's no replacement for displacement. Except Forced Indiction. N/A vs. N/A? Never a replacement.
boxer 2.5 is offline   Reply With Quote
Old 11-18-2013, 02:23 PM   #6
SmsAlSuwaidi
Boosted
Oh so his putting an ej25 and going na with it ?
This isnt some small block vs big block debate, but with alot of import motors displacement isn't everything.
Old 11-18-2013, 03:35 PM   #7
1086
1086's Avatar
Drives: UM86 - 6MT
The FA engine is stronger and apparently makes more power than the EJ engine. Crawford did a test, same size turbo, on both the EJ and FA engine. The EJ engine made 360 horsepower and the FA engine made 430 horsepower - same turbo, smaller engine... hmmm - you might just want to stick with what you got
1086 is offline   Reply With Quote
The Following 4 Users Say Thank You to 1086 For This Useful Post:
EvilBeaverFace (11-19-2013), FRSToyota86 (11-18-2013), SirBrass (11-19-2013), suaveflooder (11-18-2013)
Old 11-18-2013, 04:01 PM   #8
FRSToyota86
would assume extra displacement would make a significant power gain. Ken and Yoshioka both have 2.5lt engines no? I wish there was an in-debt write up about jdm engine swaps.
If you could find a great deal on a used engine. In theory it would cost just about the same as going with a premium turbo kit.
I am sorry for opening a can of worms, I m just trying to weight my options and learn more.
Perhaps I should give up engine swap and go with a turbo kit but i wont be the same. Anyways that engine would be awesome on gt86 platform.
http://www.importtuner.com/features/.../photo_12.html
Old 11-18-2013, 04:24 PM   #9
1086
1086's Avatar
Drives: UM86 - 6MT
If you have the money to do an engine swap, plus replace parts and deal with all of the unknowns with regard to fitment and placement - go right ahead - but at the same time it seems to be more trouble than its worth. Do you want to go through that whole process? What are you looking to benefit/gain from a swap vs. a FI kit? Just horsepower?
Old 11-18-2013, 04:41 PM   #10
FRSToyota86
I could not afford a new crate engine at this time, but if I could if I find a used engine. It would be pretty cool to have a 2.5 sti engine that is mostly all that got me fired up I guess.
I was thinking about sc and turbo charging at the same time. but thats going to be way too expensive. Similar to MRT Performance FR-S.
Bottom line. I should just go with a turbo kit like greddy, save my money and dont complicate things. All I need is some more power at the top end for occasional track use and call it a day.
Old 11-18-2013, 07:49 PM   #11
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
I'm no expert, but I'm certain that the 12.5:1 compression ratio compared to the 8.5:1 in the EJ is to blame for the extra bump in power. Find an EJ25 at 12.5:1 and im sure you'll see more power in that engine than the FA20
lickitysplit is offline   Reply With Quote
The Following User Says Thank You to lickitysplit For This Useful Post:
STV3 (11-19-2013)
Old 11-18-2013, 08:07 PM   #12
mswhong
Drives: FT86
If an EJ had a 12.5:1 CR, then you'd see powers well above that 430hp you mentioned.. Remember, even though less displacement, compression matters when going FI
mswhong is offline   Reply With Quote
Old 11-18-2013, 08:09 PM   #13
1086
1086's Avatar
Drives: UM86 - 6MT
Well I don't know this for sure but current STI's run like 15-20 psi right? If that is the case, I don'y think that you could run that high of psi @ 12.5:1 on the EJ. I might be wrong on that though...
That would be an interesting test, however, I don't know this but what is the difference when you look at
[2.5L @ 12.5:1] vs. [2.0L @ 12.5:1]
and
[2.5L @ 8:1] vs [2.0L @ 9:1]
same turbo
Old 11-18-2013, 08:11 PM   #14
SmsAlSuwaidi
Boosted
Not every block is built to withstand 12.5:1, and DI helps a lot with high cr , Ferrari now has a 14:1 engine that runs on pump
Sent from my IBrick
Engine Swap Whiteoutjames Engine Swaps 21 02-25-2013 09:54 AM
4-AGE engine swap on FR-S bacon_cheese_beer Scion FR-S / Toyota 86 GT86 General Forum 31 12-16-2012 02:23 PM
4-aGE engine swap on FR-S bacon_cheese_beer Engine Swaps 13 12-15-2012 03:29 PM
Engine Swap cf6mech Engine Swaps 21 11-16-2012 02:52 AM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
