Old 06-28-2014, 04:53 PM   #1
Chimera
Drives: FRS
After unhooking the battery. [Q]
So I understand that unhooking the battery resets the ecu. Does anyone else have to pump the clutch and attempt to start about 5-7 times before it turns over or even attempts to start?
Old 06-28-2014, 05:55 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Why would you need to pump the clutch...?
It sounds like their is an issue with your clutch and it's not disengaging the trans from the engine.
Maybe a leak in the system?
N1rve
Old 06-28-2014, 07:30 PM   #3
Chimera
Drives: FRS
I guess the question is this: is it abnormal for the car to not start on the first attempt after reconnecting the battery?
Old 06-28-2014, 07:35 PM   #4
N1rve
N1rve's Avatar
Yes that is abnormal.
From the logical sense of it...it seems like disconnecting the battery makes your clutch lose hydraulic pressure... which means there is a fault somewhere in the clutch.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Chimera (06-28-2014)
Old 06-28-2014, 08:02 PM   #5
Chimera
Drives: FRS
That's.. Wonderful.. It's done this the entire time I have owned the vehicle.
Old 06-28-2014, 09:04 PM   #6
extrashaky
Drives: 2014 BRZ Limited
I think the clutch thing is a red herring. How could disconnecting the battery possibly cause the clutch to lose pressure?
Old 06-28-2014, 09:15 PM   #7
White64Goat
More than likely either a finnicky clutch lockout switch or it's mis-adjusted.
Old 06-28-2014, 09:18 PM   #8
Fastbrew
Drives: 2014 Pearl White BRZ
Never had the problem after disconnecting many times. It runs rough until you get through your re-calibration period but it always starts with just the button. This is with replacement air filter, intake hose and nameless down pipe/exhaust.
Fastbrew is offline   Reply With Quote
Old 06-28-2014, 09:19 PM   #9
Fastbrew
PS - if you are all stock - perhaps have the dealer re-flash to the latest map...
Old 06-28-2014, 09:24 PM   #10
Chimera
Drives: FRS
I'm running oft stg 1. It did this prior to that though
Old 06-28-2014, 09:29 PM   #11
Chimera
Drives: FRS
Also, it could have nothing to do with the clutch. That is just part of the car start procedure. Clutch, key on. It's odd to me that the starter doesn't even try.
Old 06-28-2014, 10:17 PM   #12
Cal3000
Drives: Panda FR-S
This happens to my car also. It usually takes 3 attempts before the car starts. I've flashed new maps maybe 20 times and the same thing occurred.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 06-29-2014, 12:22 AM   #13
Chimera
Drives: FRS
Just tested. On my car I can depress the clutch and leave it, but it will still take 6 on off cycles before the starter actually turns
The Following User Says Thank You to Chimera For This Useful Post:
TJ3000 (06-29-2014)
Old 06-29-2014, 12:31 AM   #14
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I think I can solve this.
I used to have a problematic Subaru Outback XT. When I would disconnect the battery to clear the codes, the same thing would happen, it would take a long time to start.
I asked a few forums why, and a guy came back with something to the effect of "the ECU is running a systems check to make sure everything is still there. It had indicated a no power situation"
If you could, disconnect the battery and reconnect it like you usually do, then when you go to start the car, switch the key to the ON position for about 10-20 seconds, then try and start it. Let us know what happens.
Bobblehead is offline   Reply With Quote
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 09:55 AM
battery jkr Engine, Exhaust, Transmission 1 04-11-2013 02:03 PM
Help with Car Battery Synack Off-Topic Lounge [WARNING: NO POLITICS] 0 01-13-2013 11:05 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
