Old 04-17-2014, 05:08 PM   #1
cpnslow
cpnslow's Avatar
Drives: 2013 Subaru BRZ Limited (WRB)
Rear Knock Developed @ 7,000mi
I've been hearing a pretty noticeable knock/pop/crack sound from my passenger-side rear corner for a month or so now.
It started around 7,000mi, so I brought the car in to Capitol Subaru service, they did a quick inspection and test drive, and found nothing. (I got back in the car and the radio was on, were they listening for the noise or just cruising in my car?)
A few weeks later, I brought the car to Stevens Creek service (wayyy better service here, as I'll soon discover) for my 7,500mi appointment. I had them do another check and they discovered the sway bar link nut was loose by about 3 full turns.
Well... turns out that wasn't the problem. I let two weeks go by, and now the knock happens over any uneven road surface at any speed. (video link below) I brought the car back to Stevens Creek this morning and the service manager took the car for a spin, he heard it immediately. They said the car isn't safe to drive and gave me a 2015 Forester loaner. I'll keep you all updated!
[ame="https://www.youtube.com/watch?v=QAujlh1eNWg"]BRZ Knocking Sound - YouTube[/ame]
My Build Thread: Nick's BRZ - "CPN SLOW"
My Car Photography: www.ngphotog.com
cpnslow is offline   Reply With Quote
Old 04-17-2014, 06:39 PM   #2
Yes, please do.
Did they say what they suspected was making that sound .. ??
Old 04-17-2014, 06:50 PM   #3
mashal
DADA
mashal's Avatar
Drives: 2013
that definitely doesnt sound good
mashal is offline   Reply With Quote
Old 04-18-2014, 12:21 AM   #4
cpnslow
cpnslow's Avatar
They said it sounds like part of the structure in the strut tower may have failed, possibly a weld. My car is totally stock.
Old 04-18-2014, 01:27 AM   #5
Well, then .... that ought to fix up so it's good as new ....
Old 04-18-2014, 01:47 AM   #6
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
That sucks. Mine had a knock on the passenger-side rear for a while when I would cruise at 70+mph. Turned out to be my oem spoiler was flapping around. The double-sided tape had let go.
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 04-18-2014, 05:34 AM   #7
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
That sounds like the frame is falling apart. :O
It doesn't sound good at all... interested to know what it is.
N1rve
Old 04-18-2014, 10:29 AM   #8
wheelhaus
wheelhaus's Avatar
Technically the rear shocks aren't struts, it's just a shock so it takes no lateral loads.
I'm having a hard time deciphering what noise you're talking about in the video, is it the higher pitch pop/click (heard from 5-9sec and again at 20sec) or the lower pitch thunk/groan sound heard from 9-12sec?
The noise could be from the shock assembly itself, or any of the suspension components, or it could be the rear deck pop/noise many members had a while back.
http://www.ft86club.com/forums/showt...r+deck+popping
The Following User Says Thank You to wheelhaus For This Useful Post:
cpnslow (04-18-2014)
Old 04-18-2014, 06:36 PM   #9
Ghost 86
Drives: 2013 Whiteout FR-S
My frs drivers side shock went bad around 5k miles replaced under warranty. I had that same noise drove me nuts
Ghost 86 is offline   Reply With Quote
Old 04-18-2014, 11:48 PM   #10
cpnslow
cpnslow's Avatar
Just got my car back. The service team said they had found popping coming from several sources and "adjusted several weld areas and lubricated". Driving home, I heard nothing. I'll let you all know if it comes back.
Old 04-18-2014, 11:55 PM   #11
cpnslow
cpnslow's Avatar
You can hear it twice pretty clearly at 10 and 11 seconds, its a high pitch pop.
Old 04-19-2014, 12:06 AM   #12
gramicci101
Off Topic
What does "adjusted several weld areas" mean? They rewelded something?
Old 04-19-2014, 12:28 AM   #13
wheelhaus
wheelhaus's Avatar
probably bent, er, I mean "tweaked" something...
Old 04-19-2014, 04:52 AM   #14
..... ....... most likely with a big hammer, then squirted some WD-40 around the area .....
brz, crack, knock, pop, subaru
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 11:09 PM
My Turbo Kit developed by KAB Customs in South FL Sportsguy83 Forced Induction 390 04-30-2015 10:35 AM
FS: VDS UEL Headers for 86/BRZ (Newly developed) sanj424 Australia Classifieds 0 03-28-2014 02:37 AM
Report: Supercharged Toyota 86 being developed by TRD!! Craikeybaby Engine, Exhaust, Transmission 205 03-04-2012 04:42 PM
Navy developed and tested a railgun SVTSHC Off-Topic Lounge [WARNING: NO POLITICS] 21 03-01-2012 08:43 PM
