Software Hobbiest
Drives: 2015 FRS
Tune Help
I just installed the sbd500x kit and flashed the base turbo tune I need some help with my stft and ltft.
https://datazap.me/u/dholloway543/de...=0&data=7-8-10 What should i change via rom raider to get the fuel trims better? |
#2 |
Drives: brz 2017 hksv2
Check for exhaust leak near the lambda sensor first
#3 |
Drives: FT86
As above check for exhaust leaks before or near 02 sensors, your ltft is huge positive.
Check tune has correct injectors scaled to match current injectors Check the direct injection computer is bolted up to engine with all three bolts Check your flex kit connection if your running flex, and that ethanol reading is same as what fuel is in tank. Check tune has correct intake\maf scaling to suit intake pipe used. Something is causing a fueling error of over 30% or a perceived fueling error. |
#5 |
Software Hobbiest
Drives: 2015 FRS
I need a tune but it's Sunday . My ltft is still at 40 after tightening everything from intake back to exhaust tip. I have no cell either
#6 | |
JDM Vaping Stance Nation
Drives: 2013 White
My LTFT was high for a while, got worse over time. I tightened everything I suspected and sprayed water. Took it to a shop finally since I was getting CEL for lean. LTFT shot up to 30s. It ended up being the PCV valve that got loose. They smoke tested it. Also check the intake hoses under the manifold. I clamped those off and that helped a little, cleared a code.
Clueless
#7 |
Software Hobbiest
Drives: 2015 FRS
Turns out a good tune goes a long way. Im working with my tuner and he got my stft and ltft to 0 while driving and rn its at 20 idling. The car no longer smells of gasoline and its not running rich. Must have been the wrong map sensor and the tune
#8 | |
2013 Series 10 FRS #553
| OpenFlash Headers in 2017 &a Tune -- success & no tune yet | gskv | Software Tuning | 151 | 03-29-2018 08:10 PM |
| B01D 6AT SBD Turbo Tune Questions *Tune Attached* | Pro60modman | Software Tuning | 6 | 09-05-2016 09:04 PM |
| How can you trust a tune? (tune noob) | Benschneider06 | Software Tuning | 20 | 05-21-2015 11:03 AM |
| Drift Office Tune vs Visconti Tune | mechaghost | Engine, Exhaust, Transmission | 109 | 07-03-2014 12:57 AM |
| difference between vortech tune and perrin tune? | Frs32907 | Forced Induction | 7 | 12-05-2013 02:49 PM |
