Old 05-17-2014, 08:53 AM   #1
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
Cusco Power Braces on DD BRZ/FRS
I've been doing some research on Cusco and what they had to offer. I am considering buying all the Power Braces for the chassis to include the FSB and RSB. Has anyone have a majority of these braces installed on their car? Does the car shake a lot? It's just a consideration right now. I will be DD this car. It will probably see ZERO track time and that is fine with me. I understand that it might be wasted $ but I will be happy with it if it does what I want, reduce chassis roll and improve handling.
blackhawkdown is offline   Reply With Quote
Old 05-17-2014, 09:11 AM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
It is a waste of money IMO. They don't do anything but make the car heavier.
- AdrianG
AdrianG is offline   Reply With Quote
The Following 2 Users Say Thank You to AdrianG For This Useful Post:
Calum (05-17-2014), suaveflooder (05-17-2014)
Old 05-17-2014, 10:11 AM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
X2
Old 05-17-2014, 10:27 AM   #4
Lavalover
Drives: 2014 FR-S Monogram Hot Lava
There is an entire thread on this topic a few rows down.
Lavalover is offline   Reply With Quote
Old 05-17-2014, 11:06 AM   #5
was385
Drives: MT WRB BRZ Limited, 2007 911s
The overwhelming opinion is that they don't do anything and the money could be spent much more effectively elsewhere. This isn't some econobox chassis that has been repurposed. It was built to be a stiff sports car chassis from the ground up.
was385 is offline   Reply With Quote
Old 05-17-2014, 01:10 PM   #6
Roadliner
Drives: GT86
TRD underbody brace kit, TRD carbon fibre strut bar, TRD door braces, TRD/STI engine mounts and transmission support.
Running just the brace kit and strut bar, there was a difference already with how the car felt over bumps( more all of one piece feeling) and through bends (less body roll).
Even a fellow 86 owner sitting as a passenger could feel how good the chassis feels.
After putting in the door braces and mounts, the car feels even better.
All of this on stock suspension that I have no intension of changing and all stock bushings which I WILL be changing in strategic places.
Bracing the car up DOES make a difference but only if you go all the way. I dont think just the power braces will have much effect on their own?
hope this helps
Roadliner is offline   Reply With Quote
The Following User Says Thank You to Roadliner For This Useful Post:
Suparu (05-18-2020)
Old 05-17-2014, 01:14 PM   #7
gramicci101
Off Topic
It does, but at what price? And does something else at that price make much more of a difference? Cusco power braces are expensive; I'd rather put a nice coilover system on my car for the same price and much better result.
Old 05-17-2014, 01:21 PM   #8
CSG David
CSG David's Avatar
Based on street, canyon, and track feedback, it actually does do something. While it's not a groundbreaking development, it has small improvements in tightening up the chassis a little bit. Ping us if you're interested!
The Following 3 Users Say Thank You to CSG David For This Useful Post:
Boxer486 (05-18-2014), DylanJZA (09-17-2022), Roadliner (05-17-2014)
Old 05-17-2014, 01:44 PM   #9
blackhawkdown
hope this helps
Agreed, I plan to use some Whiteline bushings on other components.
cusco braces are pretty cheap. They range around $200 bucks or so. That is cheap to me. I don't plan on changing the suspension anytime soon as I am trying to work on saving for Ohlins just because race car.
Will do soon once I get back from deployment.
I just don't see how it does not make an improvement. Cusco is a reputable company that wouldn't make something that was useless. Adding additional weight for some chassis stiffness and improve handling, response is worth it in my book. Again, I am no professional drive or anything but I think it would make an improvement.
Old 05-17-2014, 01:50 PM   #10
Roadliner
Drives: GT86
you have a very valid point there.
The way I see it, getting coilovers wont bring out the best without supporting bushes, camber adjustments and supporting hardware, tyres. Going FI without supporting chassis mods wont be very nice to drive too.
But bracing the chassis as far as it will feasibly go and moving to the bushes from there, followed then by coilovers and finally FI means being able to enjoy the car as a 'whole' if that makes sense? Every step along the way, the car isnt compromised by each change, rather its just getting better overall.
Old 05-17-2014, 01:55 PM   #11
CSG David
CSG David's Avatar
On a side note, list the goals you have for the car such as the look, the feel, the actual application. This will guide you towards a direction that will satisfy those goals. We may have some sort of plan for you to work off of to satisfy your goals without sidetracking yourself.
Old 05-17-2014, 01:56 PM   #12
blackhawkdown
I agree with you. Coming from built WRX and STi, I can say that I learned a lot of do's and don'ts. Start building power without proper chassis and breaking system upgrade makes the power useless. This time around, I am gonna build my chassis and suspension first before I start to build power.
The Following User Says Thank You to blackhawkdown For This Useful Post:
Old 05-17-2014, 03:28 PM   #13
fatoni
i dont think thats the case. when you go to mod a 30 year old corolla, the chassis support makes sense because with 200 treadwear tires, the door light would come on under lateral loads. those braces might do something but im sure the sways are doing about 95% of what you would be feeling. going with sway bars before coilovers can make sense but if youre intent on getting coilovers i would wait. its kind of like adding salt to your plate before you have the steak imo.
there are plenty of cars running coilovers and ridiculous tires without the cusco brace with tons of success so you shouldnt worry about it.
The Following User Says Thank You to fatoni For This Useful Post:
Old 05-17-2014, 04:18 PM   #14
was385
I completely agree that suspensions mods should be first but those braces just aren't necessary IMO. This is a true sports car chasis that is already plenty stiff. If you do everything and at the end you still want more, I'd say go ahead but I would put chasis braces really close to the end of my list. The money would go a lot farther elsewhere IMO.
Cusco Braces Review Unleashed Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 09-11-2021 03:00 PM
WTS Cusco Strut Tower Bar / Adjustable Angle Braces and more ryansb Hawaii 1 10-29-2013 01:45 PM
help finding proper torque for coils and cusco braces three3y3wrbbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-23-2013 05:25 PM
Cusco Front & Rear Strut Braces [BNIB] GC GTS Aero Kit Australia Classifieds 8 12-04-2012 08:58 AM
