Old 05-12-2014, 10:29 AM   #1
Wepeel
Drives: '13 BRZ Ltd
Oil on/around Intake Manifold
So I started noticing some oil spots on the intake manifold, on the driver side. Looked around for a bit, but can't seem to find where it's coming from. I'm thinking it could be some pcv/breather/evap line that came disconnected, but before I take it in to the dealer I'm just wondering if anyone else has experienced this?
Seems like guys in the FI forums seem to have issues with lines popping off but I am NA.
Wepeel is offline   Reply With Quote
Old 05-12-2014, 09:13 PM   #2
Dezoris
Dezoris's Avatar
Where are you seeing oil specifically? Breather tube is behind AC compressor but that does not easily come loose. Sure its not the AC compressor. Any oil pooled by fiiter sandwich plate?
The Following User Says Thank You to Dezoris For This Useful Post:
Wepeel (05-13-2014)
Old 05-13-2014, 12:40 AM   #3
Wepeel
Drives: '13 BRZ Ltd
It was on the edge of the intake manifold, on the driver-front runner, and also in the valley between the front/rear runner just under the D4S plate. Also noticed some on the wire with the blue harness near the driver front under the manifold, I think that's the direct injector solenoid harness?
I just realized I did trans fluid swap recently and had the funnel wedged against the intake manifold. I'm hoping I just dripped some gear oil on the manifold parts and it spread out with heat/time/etc. When I went to wipe it up it wasn't that much. It's all cleaned up now, I will check to see if anything new appears.
FBM Intake Manifold Release FullBlown Forced Induction 426 03-19-2019 04:23 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 02:43 PM
Wanted intake manifold ciro Want-To-Buy Requests 0 09-27-2013 01:03 PM
Aluminium intake manifold? Hempo Engine, Exhaust, Transmission 18 06-27-2013 02:19 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 03:24 PM
