Old 02-18-2014, 01:38 AM   #1
notout86
Drives: GTS 86 auto
Wish list
After 9 months/14000Km ownership of a GTS auto
Open letter to Toyota and Subaru.
You had a good thing when you launched the '86/BRZ. We thought the fun factor for the price was unmatched. but I believe existing owners are beginning to wonder if they will get the next release. Would-be new buyers must be surely realising that there are several less overtly sporting cars worth considering.
Competitors have progressed and to gain repeat business (myself included) and new purchasers, here's what I'd like to see:
Keep the base model as a platform for modders who want to do their own.
For the GTS
Keep price the same to match competitor value.
At all costs, retain the fun-factor which the competition lack.
Increase engine torque and have it delivered wide-range ... there are plenty of such turbo engines around now with great driveability, minimal lag, similar power but much higher torque, not to mention with better fuel economy and in lower or similar priced cars.
Improve rear visibility
Change the nose which scrapes too easily ... what about a speed-variable clearance. Maybe it could be passive with air speed.
Have the doorside bolsters of the backrests of the seats open to ease getting in and out.
Quit the round speedo ..... no-one looks at it as the digital is fine. Replace with oil temp, g-force gauge, digital combo gauge as option
Quit the heated seats. Quit the lights washers. Quit the sound tube. Make them options. Use the savings elsewhere.
Sharpen the low speed turn-in and reduce the turning circle
Cruise control and audio system thumb operated on steering wheel. Instead, delete the paddles which I like but would gladly swap for cruise and audio on the wheel.
Cruise control in auto models that controls car speed better. e.g. set to 60kmph but trans allows speed to reach 69kmph before change-down for engine-braking effect.
GPS with voice control that is more user-friendly.. after command " find address" the next question should be "what State and Suburb or Town" etc. ... i.e. following the same steps as for touchscreen
GPS that can be owner-updated at anytime for no charge.
Quieter cabin noise levels.
User preference settings e.g. to start with cruise control on, sports mode on, air recirculate off
Park assist or at least front+rear parking sensors or cameras
Discussion invited
GTS86 Auto (Australia)
Old 02-18-2014, 01:48 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
For the GTS
Will require a entire redesign.
Ive scraped even on a camry... buy an air suspension.
What bolsters? You mean add more doors?
In some countries, the base model does NOT have the digital gauge.
Light washers? I never knew these were an option.
Heat Seats? Don't get the top of the line one then?
I like the sound tube...makes moar noise.
I don't understand this complaint.
The cruise control is standard Toyota-like cruise control. It's like that for the majority of the cars. Audio on the steering wheel? No thanks. It makes it harder to hook up a new sound system
That's not the point of cruise control.
Buy an after market system.
Sound deadening.
Why would you start with cruise on!?
Are you that bad at parking? This IS a drivers car...
Discussion invited
/endrant.
The Following 3 Users Say Thank You to N1rve For This Useful Post:
humfrz (02-18-2014), Sonolin (02-19-2014), suaveflooder (02-18-2014)
Old 02-18-2014, 02:15 AM   #3
Sorry, I got lost in trying to translate ...??
Old 02-18-2014, 02:23 AM   #4
N1rve
N1rve's Avatar
It's Okay. I got it
The Following 2 Users Say Thank You to N1rve For This Useful Post:
humfrz (02-18-2014), suaveflooder (02-18-2014)
Old 02-18-2014, 02:57 AM   #5
suaveflooder
lol!!! Basically, OP wants a BMW
suaveflooder is offline   Reply With Quote
The Following 2 Users Say Thank You to suaveflooder For This Useful Post:
OICU812 (02-18-2014), Sonolin (02-19-2014)
Old 02-18-2014, 03:50 PM   #6
Razz
Razz's Avatar
Drives: Fast
A very young driver, indeed!
Razz is offline   Reply With Quote
Old 02-18-2014, 04:06 PM   #7
Mikem53
Drives: FR-S 6MT
OP
You bought the wrong car..
Mikem53 is offline   Reply With Quote
The Following 4 Users Say Thank You to Mikem53 For This Useful Post:
Sonolin (02-19-2014), strat61caster (02-18-2014), Tim_Asphalt_FRS (02-18-2014), travelmonkey (02-18-2014)
Old 02-18-2014, 06:53 PM   #8
funwheeldrive
Dear Toyota,
Keep up the good work.
-FWD
The Following 2 Users Say Thank You to funwheeldrive For This Useful Post:
mav1178 (02-18-2014), Tim_Asphalt_FRS (02-18-2014)
Old 02-18-2014, 07:04 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Please make Gran Turismo real life.
I fixed that for you, because that's what it seems like you want.
Most of what you listed isn't practical at all.
-alex
Old 02-18-2014, 07:32 PM   #10
Basket Case
Drives: 2013 Raven fr-s
if you wanted these things you should have bought a bimmer. Not saying that to troll. I have owned bummers, you are describing that...
Basket Case is offline   Reply With Quote
Old 02-19-2014, 12:01 AM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
1.the nose does scrap easily.. the car is very close to the ground, because it is a sports car... the trick is to understand how to get across obstacles that would normally scrape on-- like approaching speed bumps on a diagonal.. i'm quite sure variable-speed clearance would raise the cost of the car significantly..
2.this might be exactly waht you need
http://www.easycomforts.com/buy-swiv...cushion-311685
3. really? this is the easiest car i've ever parked.. i really suggest you take some time to drive some larger vehicles.. after driving a suburban, a chevy utility van with no rear windows, and 2 different models of convertibles with massive steering radius' and blind spots that can hide semi trucks, this is the easiest car i've driven since i started driving..
one more car list... Axel Off-Topic Lounge [WARNING: NO POLITICS] 20 12-18-2013 07:17 AM
What's on your list? TheGuyWithTheFireStorm Off-Topic Lounge [WARNING: NO POLITICS] 5 11-27-2013 07:16 AM
CEL list? draggin_az Issues | Warranty | Recalls / TSB 2 05-14-2013 04:25 PM
Mod list before car, anyone else? Shadowsong6 Scion FR-S / Toyota 86 GT86 General Forum 13 03-01-2013 09:53 AM
TSB list? DarrenDriven Issues | Warranty | Recalls / TSB 15 11-03-2012 08:38 PM
