Old 10-29-2014, 10:24 AM   #1
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
10 or 15mm spacers on 17x9 +42
This beast needs some camber bad... I'd like to find some 10mm bolt-on spacers but i cant find ANYTHING. a coworker of mine has some 10mm bolt-on project kiks or something on his evo but i've yet to find them again... I just want to get 1.7 or 1.8* of camber up front.
Does anyone know where to get these? I'd much prefer to not have to press studs so bolt-on is prefered but would you guys go with a 10 or 15mm spacer either way...
here is how the car sits now... i will have hotchkis 1" drop springs on it when i put spacers on it.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 10-29-2014, 11:01 AM   #2
wparsons
wparsons's Avatar
Replacing the front studs isn't hard at all, and can be done in a driveway with hand tools.
Rears need the hubs pulled from the upright to get the longer studs back in.
flickr
Old 10-29-2014, 11:44 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
You would probably get better answers in the wheels section.
1974 TA22 Celica
2013 86 GT
Old 10-30-2014, 08:31 AM   #4
OkieSnuffBox
Drives: '23 BRZ Limited
I'm confused by your question.
Are you under the impression that wheel spacers somehow change the amount of camber in the suspension?
Old 10-30-2014, 12:58 PM   #5
Gunman
Drives: 2019 Mazda Miata RF
He needs to gain space between the front strut, and tire, so he can use camber bolts to add more camber.
Old 11-03-2014, 04:02 PM   #6
Roadcone
StreetKart
This. I have almost zero clearance between the tire and strut.
Old 11-03-2014, 05:22 PM   #7
jvincent
jvincent's Avatar
b2autodesigns has some decent looking bolt on spacers.
I was considering them when I was looking at new wheels. Turns out the ones I got clear the OEM spring perch by grand canyon-esque 4mm even with camber maxed out.
Old 11-03-2014, 06:11 PM   #8
wparsons
wparsons's Avatar
I'm at about 1-2mm of clearance with 17x8 +45 and -2* of camber.
flickr
Old 11-03-2014, 06:23 PM   #9
gramicci101
Off Topic
A 10mm spacer would take you to 17x9+32, which would protrude a fair amount from the wheelwell. For example, here's a 17x9+30: http://www.ft86club.com/forums/showthread.php?t=7533
F/S BNIB H&R 15mm Wheel Spacers jammz Wheels and Tires 1 04-27-2019 09:36 AM
H & R spacers 5/15mm, ARP studs jack43 Wheels and Tires 4 11-21-2014 07:04 PM
FS: 2 Ichiba 15mm spacers sw20kosh Brakes, Suspension, Chassis 3 08-04-2014 02:20 PM
(SOLD) FS: (2) 15mm, (2) 25mm B2 Auto Wheel Spacers ericmpena Wheels and Tires 9 06-17-2014 12:31 PM
FS NJ: Poweredbymax 15mm Spacers Doobster Wheels and Tires 2 03-31-2014 10:55 PM
