Drives: '23 CWP BRZ
Knocking on Startup?
So I've noticed recently when starting my car in the colder temps, when it's cold, it will make a noticable "knock" sound when I first turn it on.
It goes away, and the car doesn't make any other knocking sounds besides that, only when it's cold and it's the first start. Should I be worried?
#2 |
Drives: JAWS
#3 | |
Drives: '23 CWP BRZ
It's as it's clicking over, it sounds like it knocks hard right before it starts up. |
#4 | |
| The Following User Says Thank You to humfrz For This Useful Post: | 636 (02-01-2014) |
#5 |
Drives: JAWS
Ah, you said as you first turned it on so I assumed idle. My bad. In that case..I can't help you.
#6 |
Drives: BRZ DGM Limited
My BRZ does the same thing since day one when starting in cold weather, and I think others have report the same.
| The Following 2 Users Say Thank You to BRZnut For This Useful Post: | 636 (02-01-2014), pjpetrozelli (02-02-2014) |
#7 |
Drives: Ultramarine Scion FR-S
Does it sound like this guys video???
http://www.ft86club.com/forums/showthread.php?t=57240 |
#8 | |
Drives: tezla
the knocking from cold weather is pretty common for most cars...? |
#9 | |
Drives: '23 CWP BRZ
Nope, mine only happens for a split second, then never heard again. |
#11 |
Member of the year - 2016
Drives: Scion FRS
Are you sure it's not the pre cat warming up...?
#12 |
Drives: '23 CWP BRZ
#13 |
Drives: Whiteout FRS
@636 its something like a few knocks after you start up the car for the first time of the day then its gone the rest of the day/occurs once a while right? If so I get it once a few start up due to the car being parked outside in the cold. The rpm do drop due to the knock from what I've seen.
#14 | |
Drives: '23 CWP BRZ
| Knocking sound | Moe23 | Issues | Warranty | Recalls / TSB | 80 | 04-18-2019 09:09 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-13-2015 12:53 AM |
| Knocking/Rattle on start up. | jimbobrand | Issues | Warranty | Recalls / TSB | 18 | 01-13-2014 12:34 PM |
| STD Standard Suspension R3 Coilovers knocking | FutureFT86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2013 01:49 PM |
| Knocking sounds from lowering springs? | bbaik | Issues | Warranty | Recalls / TSB | 7 | 03-08-2013 12:50 AM |
