Drives: 93 MR2 Turbo; 2014 BRZ
Air Oil Separator Teaser Pictures
Been working on a catch can set-up for these cars for the better part of this year and finally think we have a design and mounting more or less nailed down. Figured we would share some photos and see what you guys think about it.
Everything is in the prototype phase, so bare aluminum and welded brackets. Finished product will likely be all black anodized, the bracket will be bent aluminum and also anodized black, or that is the plan. What separates this Air Oil Separator (AOS) from others is that it utilizes a filter media that is specifically designed to separate water and oil from air down to 5 microns! 5 microns is 0.00019". The filter media is still capable of flowing approximately 50 SCFM at 100 psi, so no restriction there. Basically these ensure that no oil will get from the crankcase to the intake manifold or the intake pipe. ![]() ![]() ![]() ![]() These are photos of the first prototype in design phase and prototype billet pieces. ![]() This is the second design. It features dual filters, a machined baffle, and will not need any welding. We came up with this design to ensure all oil and water get filtered out and to reduce overall costs of the can. Yes it is better and will be cheaper .![]() ![]() ![]() Current mounting is shown above. The little intake manifold cover can be used with both can placements and the bracket. The bracket will look a lot nicer and cleaner when finalized as well. Thanks! |
| The Following 5 Users Say Thank You to eric6 For This Useful Post: | 350zgoingFRS_lol (06-13-2014), FearBoy (06-13-2014), GT86_PRAGUE (09-24-2015), Malt (06-12-2014), sato (06-14-2014) |
#2 |
When In Doubt...
Drives: Slowww
Looks good, got an ETA for those in the market?
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#3 |
Off Topic
How easy is it to access the drain port? What do you think about including something like a Fumoto drain valve with a nipple instead of just a drain plug? Might be easier and cleaner to drain it that way. Or make the threads the same as the oil pan drain plug, so people could make that change on their own.
#4 |
Drain port is easy to access. It is a internal wrenching hex drain with an o-ring seal (-4 AN to be exact) and can be unscrewed with a 3/16 hex bit. We can look into utilizing a coolant drain petcock like this if that is what more people are interested in having. Our ETA is a month or two out.
#5 |
Off Topic
How easy is it to catch the oil as it comes out of the AOS? I was thinking that something you could connect a hose to might make it quicker and cleaner to drain. Just an idea.
http://i.imgur.com/l2rmhvh.jpg |
#6 |
Just a dude
Drives: Scion FR-S 2013
The filter media can it eventually get plugged / dirty and present any issues in this design? I like the fact of being able to see what's been collected vs just going back to crankcase and placement looks decent to.
#7 |
Can the weld on fittings be replaced by non weld on ones?
#8 | ||
I used a system with this same media device in it on my Evo IX for 20k, it worked flawlessly the entire time and the media never changed really. I was very happy to not be shoving the oil back into the intake manifold as well. You will have to clarify your question as I don't exactly know what you're asking. The newest catch can that has been designed does not require any welding at all. |
#9 |
Apologies, I couldn't tell just by your prototypes then the drawings that indicates this since there doesn't appear to be any threads for the fittings to screw on to.
#10 |
Because compromise ®
Drives: Red Herring
Drain petcock would be a plus for me.
#11 |
Drives: Neptune GR86
I'm surprised you didn't have a field day with that one.
#12 |
Drives: Red Herring
^^lol
yeah, I thought about it
#13 |
Drives: FR-S 10 #103 AT
His ambition in life was to be one for somebody from the first time he heard the term. Imagine his disappointment when he learned what it really meant.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#14 |
$400.
I'm still not sure why these things are so expensive. It's literally about $30 worth of aluminum and fittings |
| Air/Oil Separator - ST legal? | derek1ee | Tracking / Autocross / HPDE / Drifting | 2 | 04-08-2014 09:31 PM |
| Air Oil Separator? Do I need one? | hmong337 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 21 | 12-31-2013 11:14 PM |
| Crawford Air / Oil Separator - 13+ BRZ/FRS/GT-86 | ngabdala | Engine, Exhaust, Bolt-Ons | 11 | 06-10-2013 10:22 PM |
| Crawford Air Oil Separator | JPxM0Dz | Engine, Exhaust, Transmission | 2 | 04-16-2013 10:33 PM |
| Crawford Air/Oil Separator Installed. | Hippophobia | Engine, Exhaust, Transmission | 22 | 10-09-2012 01:01 AM |
