| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Junior
Drives: a car
Small Block Vs Big Block.
Whats the difference? I know chevy has a ton of small blocks, 350, 400, 383.
Then the 396 that came in the chevelle SS was considered a big block? wat. Ford has a 351, thats a small block and a 352 is a big block? Im confused.
#2 |
Drives: 13 GBS BRZ
Big blocks are heavier, contain more metal, can withstand higher compression and heat, and are also generally more durable. The blocks have the cylinders further apart.
#3 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
You forgot the Chevy 348 cu in BIG BLOCK!
So many modders have more cents than sense!
| The Following User Says Thank You to Rampage For This Useful Post: | cdrazic93 (05-10-2015) |
#4 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
Should cover it.
[ame="https://www.youtube.com/watch?v=LPZuEWli4gQ"]Big Block and Small Block what's the differance - YouTube[/ame] |
#5 |
Benched 86lb
Drives: Ultramarine FR-S
The answer to this question is actually pretty vague. I watched the first part of the video but didn't like the answer it gave.
There is no standard for "small block" and "big block". Intuitively, however, you would expect a big block to be 'big' and a small block to be 'small'. GM makes an engine called the "small block". It's a 90 degree crossplane V8 with overhead valves and pushrods. They also make one called the "big block" which is very similar, but bigger. This is a lot like a couple having two boys and naming them "old son" and "young son". Indeed, the young one is younger than the old one. Both GM engines had displacement increases over the years, so the small block went from an initial 265CI to 400CI, and even 454CI in aftermarket. The big block went from 396CI, down to 366CI, then up to 496CI, and to the moon in the aftermarket. The video talks about differences between the valve angles, positioning of the intake and exhaust ports, etc. This has nothing to do with "small" versus "big", and is actually just a comparison between the two GM V8s in question. When the small block came out, it was considered a compact engine, especially for its displacement and power. Calling it a small block made total sense wrt marketing. Then when the big block came out in the 60s, big was considered good, and it is bigger than the small block, so they called it the big block. Some people refer to certain Ford V8s as "big block Ford" engines. In this case, it's really just a slang way of saying "big ass V8 made by Ford". Ford has used the same inches for different engine families, so you may hear of a 351 "big block" or "small block". A 351 Windsor would probably be the "small block", while a 351 Cleveland would be a "big block" (might need to fact check that though). As far as I can tell, no one besides GM has officially embraced "small block" and "big block". |
#6 |
Drives: frs
For me Dodge make the big block more nasty, i mean hemi cylinder with high comp
Nice video also, very informative Big is always better, ask any women |
#7 |
Drives: 2015 BRZ
Wikipedia actually has some decent write-ups about the history of the various block designs from Ford, GM, and maybe AMC. A bit of link-following there should provide a solid education.
Remember that there are essentially three main things at work here when people refer to a big block/small block of X displacement: the actual engine block itself (which can be big, small, industrial, medium/heavy truck-size, marine, etc.) and then there are the bore and stroke measurements which in combination creates the displacement. So you can have different blocks which, through different bore and stroke measurements, all yield the same displacement. Differences in application call for big/small block choices, favor RPM over torque, seeking a block with a lot of metal in it versus a lighter (or aluminum) one, or seek out a rod/crank/piston setup with lighter reciprocating mass, etc. [ame="http://en.wikipedia.org/wiki/Ford_FE_engine"]Ford FE engine - Wikipedia, the free encyclopedia[/ame] This link has a bit of history about one of the "medium-block" Ford engines, but also has a chart at the bottom relating to Ford v-8 engine bore spacing, which might be helpful in getting a sense of the dimensional constraints of the different blocks. |
#8 |
Hotlink Terrorist
Big block versus small block Nissan.
| The Following User Says Thank You to themadscientist For This Useful Post: | Tcoat (05-11-2015) |
#9 |
Pretty much sums it up in two pictures.
#10 |
Site Moderator
Drives: Stuff
Really it's the physical size of the block. Gm big blocks did use a different pushrods/valve angle I'm fairly sure but that's not specifically meaningful.
The big block in my burb makes nice torques.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| WTB: FA20 Long Block/Short Block blown/running | The Racers Line | Engine, Exhaust, Bolt-Ons | 7 | 07-29-2014 02:26 AM |
| WTB: FA20 Short Block or Blown Long Block | The Racers Line | Want-To-Buy Requests | 1 | 06-29-2014 06:21 PM |
| New Kid on the Block | 503 BRZ | Northwest | 51 | 12-15-2013 07:04 PM |
| WTB: short block or long block | DOTman05 | Engine, Exhaust, Bolt-Ons | 2 | 07-14-2013 07:48 AM |
