Old 10-10-2013, 12:08 PM   #1
VoiD
Drives: 13 WRB BRZ
Opticoat fail?
I just noticed this today.. after heavy rain, in my work garage.
Got opticoat done in March, car has been parked in garage..
Is this sign of failure in just 7 months?
i see no beading on roof/ front hood and bumper. Trunk still beads well..
do I need a new coat or is it even worth it?
VoiD is offline   Reply With Quote
Old 10-10-2013, 12:18 PM   #2
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Try washing it. I have had problems with that after going to the track, having it all dirty. After I washed it, came back to its normal beading awesomeness.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
The Following User Says Thank You to akuhei For This Useful Post:
VoiD (10-10-2013)
Old 10-10-2013, 12:28 PM   #3
VoiD
Drives: 13 WRB BRZ
Thank you.. will try that..
Old 10-10-2013, 12:40 PM   #4
kanundrum
Drives: 2013 Whiteout FR-S
Subbed
Old 10-10-2013, 02:15 PM   #5
DetailersDomain
DetailersDomain's Avatar
Drives: Audi S4
please wash it like you would, I believe you should see some beading.
typically beading isn't one of the prominent features of opti coat.
DetailersDomain is offline   Reply With Quote
The Following User Says Thank You to DetailersDomain For This Useful Post:
VoiD (10-10-2013)
Old 10-10-2013, 10:51 PM   #6
Greg Nichols
Paint Correction Guru
Greg Nichols's Avatar
Drives: F150 Platinum
Spray down the entire car during the wash process with something like Optimum power clean 3:1. In the photos the paint looks dirty. Allow the cleaner to dwell on the paint and then rinse and re wash.
If it did fail it wasn't the coating, it was the application of the coating. Your installer should re install then.
Cheers,
GREG
Reflections Detailing of Utah
"Detailing for the discerning owner"
Meguiars/Ford detailing team SEMA 2010 and 2011
Ask a pro blog writer for detailed image
duPont Registry approved detailer
Greg Nichols is offline   Reply With Quote
The Following User Says Thank You to Greg Nichols For This Useful Post:
Paul_S (10-11-2013)
Old 10-24-2013, 06:13 AM   #7
imom
Drives: BRZ sold
Are you applying wax and how long has it been that you applied Iron X? There were post before that you just need to remove the wax and other bits so the OC can do it's job.
imom is offline   Reply With Quote
Old 10-24-2013, 08:20 PM   #8
David-Fermani.com
David-Fermani.com's Avatar
Drives: Dirty
Get some advise from your installer. The car/paint looks dirty and might need a good cleaning depending on the build up that may be on it.
Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
Official Optimum Opti-Coat PRO Application Specialist for Metro Detroit
David-Fermani.com is offline   Reply With Quote
Old 10-25-2013, 05:56 PM   #9
DSlayerZX
Drives: 2010 Corolla, 2013 Fr-s
The reflection on the paint suggest that the pain might be dirty.
Do you wash the car on regular bassis?
Have you try to apply something over the opti-coat?
If the top two has been yes.. you might want to try light claying a small portion of the car and see if it helps.
Opti-coat should not fail that fast. I got mine done at about the same time as you, I park in an underground garage and outside from time to time, the coat is still functioning as when I first got it applied.
DSlayerZX is offline   Reply With Quote
Hella Fail SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 117 01-14-2013 12:59 PM
BRZ to be AWD, straight from SOA (fail) Laika BRZ First-Gen (2012+) — General Topics 22 03-05-2012 11:09 AM
presidential fail RRnold Off-Topic Lounge [WARNING: NO POLITICS] 3 05-23-2011 08:54 PM
If the FT-86 is a fail...what will you do? SteelReign Scion FR-S / Toyota 86 GT86 General Forum 172 04-28-2011 03:49 AM
