Old 10-29-2013, 04:15 AM   #1
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Starting in 2nd Gear?
So, as I'm learning stick, I'm still really jerky starting in 1st and shifting into 2nd. I'm curious about starting in 2nd gear instead because I feel a lot more competent shifting between 2nd and 3rd and so on.
I've tried to do some research on it, but I've read conflicting reports. Some say it will wear the clutch faster because you're slipping it a bit longer. Other's say they start in 2nd gear and see their clutch last 80-100k miles. What's more, I've seen others state that close-ratio transmissions can start in 2nd just fine.
Obviously, I will try to learn how to start in 1st properly, but I'm just wondering if starting in 2nd is a viable option for this car? I tried searching the forums for existing topics, but no dice.
Manic is offline   Reply With Quote
Old 10-29-2013, 04:23 AM   #2
hattorihanzo
hattorihanzo's Avatar
Drives: 2007 Lexus IS350
I think first is there for a reason. Don't think second gear start off is a great idea...
hattorihanzo is offline   Reply With Quote
Old 10-29-2013, 04:25 AM   #3
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Start in first and ur car will be happier, do will ur tires and gas tank. U start in second only 1 of 2 ways.
A) lots of wheel spin from dumping it. This burns tires and gas.
B) lots of bogging down from not enough gas. This will consume more gas to get up to speed.
Obviously neither are going to brake the car acceptionaly fast by any means. But the car wouldn't have a first gear if it didn't serve a purpose.
If ur having trouble, first get is always the trickiest. Do what I did, find a hill and practice start/stoping with out killing it. Once you learn to feather the clutch/gas you are golden.
FRSfan111 is offline   Reply With Quote
Old 10-29-2013, 04:33 AM   #4
Manic
Is not fast.
Manic's Avatar
Interesting. While I was out practicing tonight, I tried a couple starts from 2nd. Even with wet roads (rained a couple hours ago), I didn't have any wheel spin or engine lugging. I did admittedly slip the clutch longer than I would have in 1st, but only by a half second or so.
I'm not trying to defend starting in 2nd or anything like that, I understand that starting in 1st is better for the car and a better practice in general. I just want to see if anyone else here starts in 2nd and if so, what has their experience been.
I do appreciate the responses though, all input is useful!
Old 10-29-2013, 04:37 AM   #5
FRSfan111
Lol in all honesty I can start this car in third or even fourth. The gearing is so close. But I wouldn't recommend it.
Old 10-29-2013, 06:33 AM   #6
alan.chalkley
Drives: 4wd zooks
What about handbrake hill starts or edging forward in a traffic jam?
First gear is there for good reason.
alan.chalkley is offline   Reply With Quote
Old 10-29-2013, 07:00 AM   #7
ft_sjo
Drives: GT86
Old 10-29-2013, 07:44 AM   #8
z3ro
I don't see any issue with 2nd gear starts. No wheels spin whatsoever (doesn't make sense that you'd spin in 2nd but not in first) and no real engine lugging. With such a short 1rst gear, 2nd is almost perfect to start off in on flat ground or downhill. I wouldn't recommend it for hills though.
z3ro is offline   Reply With Quote
The Following User Says Thank You to z3ro For This Useful Post:
strat61caster (10-29-2013)
Old 10-29-2013, 08:51 AM   #9
Mikem53
Drives: FR-S 6MT
Figure it out.. 1st gear is there for a reason.. Learn how to drive a stick and use it. Takes practice to get it right.. Slipping 2nd gear is dumb.
By an automatic if you can't figure it out..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
AznKirby (11-02-2013)
Old 10-29-2013, 09:12 AM   #10
frosty86
frosty86's Avatar
Drives: '13 FR-S (Whiteout) Manual
If I'm going downhill from a complete stop, I just ease into 2nd gear smoothly while the car rolls forward. Otherwise I use 1st gear to start. I just don't like the sound of engine bogging in 2nd gear on flat ground - besides, it requires extra energy and time to start movement from a higher gear.
frosty86 is offline   Reply With Quote
The Following User Says Thank You to frosty86 For This Useful Post:
Ozzman (11-04-2013)
Old 10-29-2013, 09:38 AM   #11
JDMenrique
DEEEERP
JDMenrique's Avatar
Doing a clutch pedal adjustment (in the DIY section) is really gonna help you.
JDMenrique is offline   Reply With Quote
The Following User Says Thank You to JDMenrique For This Useful Post:
Suberman (10-29-2013)
Old 10-29-2013, 09:46 AM   #12
Nm86
Drives: Ultramarine
If you had really low gears, say a jeep rubicon. 1st gear in that goes to like 15 at redline,then you may consider starting in 2nd, but this 1st gear is not that short, 30+ mph in a gear is not short. But if u don't like shifting why not just start in 6th, I mean what could it hurt? You would just need to slip the clutch for like 30 seconds, take it to an extreme when you think about it, that will allow you to see the damage you are causing.
Nm86 is offline   Reply With Quote
Old 10-29-2013, 09:51 AM   #13
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
start in 1st, just practice more
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
Old 10-29-2013, 09:57 AM   #14
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Probably nothing wrong with starting in second but instead I suggest you work on polishing your skills. Try starting in first gear but not taking it up very high in the rpm range. Start slow and shift into second 'slowly'. Use first gear to do little more than get the car rolling. It takes a lot of practice to become good with a manual. Don't give up. Keep in mind that just because a person drives a car with a manual transmission doesn't mean they have to drive it hard. You can drive a manual as nice and easy as your neighbor can drive his automatic.
whaap is offline   Reply With Quote
The Following 3 Users Say Thank You to whaap For This Useful Post:
Evil Jesus (10-29-2013), humfrz (10-29-2013), kthxbai (11-02-2013)
starting in second gear cantaloupe BRZ First-Gen (2012+) — General Topics 38 03-11-2013 07:18 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 01:08 AM
Another way of starting from 1st gear..help tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 32 09-24-2012 01:14 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
