Old 08-01-2013, 11:43 PM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
RaceRom acceleration timer.
Can anyone explain what the 4 timers based on distance that comes with the Ecutek racerom maps do?
I know there is 4 of them. 0-60 1/4 mile time I think? Not sure what the other two are.
I also don't know how to change between them. Is each one on a different map... or are they all enabled and you can cycle through them somehow?
I had it enabled today. however when I enable my racerom map turn it to the current mpg numbers and do a 0 to 60 run. It says 1.5 or something holds that number for 30 seconds and goes back to normal until I stop again.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-02-2013, 11:50 AM   #2
feldy
feldy's Avatar
Just for the unaware.
the 1/4 mile times.
[ame="http://www.youtube.com/watch?v=eFs9kMUn63w"]FRS/BRZ EcuTek 1/4 Mile Dash Display(Visconti Tuned) - YouTube[/ame]
and the 0- 60 times
[ame="http://www.youtube.com/watch?v=V0J1hBT48vI"]FRS/BRZ EcuTek 0-60 Dash Display(Visconti Tuned) - YouTube[/ame]
Just not sure how to cycle through them.
Old 08-02-2013, 01:03 PM   #3
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
thats my car in the video...each map had a different display. air fuel ratio, 0-60, 1/4 mile, fuel percentage. for 0-60 and 1/4 mile you had to set it to which ever map it was on. when the 3 dashes appeared you were ready to start your run..it would count up until you reach 60 or 1/4mile(which ever one you were on) and when you were done it was flash to a stable number for about 5secs...im not sure if the mixed the fuel meter while using these displays but if your gas meter starts to go down to e very fast then it is not fixed yet
brichard0625 is offline   Reply With Quote
Old 08-02-2013, 01:27 PM   #4
feldy
feldy's Avatar
Ahh cool. For some reason I thought you could cycle through them. But I guess not. Shucks.
Old 08-02-2013, 02:34 PM   #5
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
What tires do you have? And can you please explain in detail how you're using launch control? I know how to adjust the rpm, and how to activate it. I'd just like to know your technique for clutch control and what not.
post_break is offline   Reply With Quote
Old 08-02-2013, 07:35 PM   #6
brichard0625
i was on stock tires and rims with tires deflatted a little. For launch control i learned that setting the rev limiter a little past 5k(at least on my car) is the sweet spot. When i am ready to launch i fully disengage the clutch and try my best to break out of wheel spin by letting go of the gas just a little until i feel i have the traction to go full throttle. Right now on stock car with 93 tune best 0-60 is 5.8secs/1/8mile 9.3secs(torque app)(from what i recall)
Old 08-03-2013, 11:34 AM   #7
Ch3cho86
Ch3cho86's Avatar
Drives: Scion FR-S
I can't find how to activate these features. How can I activate them?
Ch3cho86 is offline   Reply With Quote
EcuTek RaceRom Questions. feldy Engine, Exhaust, Transmission 7 02-12-2014 05:07 PM
First Timer posting PICS gvan1998 Scion FR-S / Toyota 86 GT86 General Forum 7 05-31-2013 08:30 PM
EcuTek racerom feature help lbroskee Engine, Exhaust, Transmission 10 05-08-2013 11:45 AM
RaceROM Features Demo'd JPxM0Dz Engine, Exhaust, Transmission 13 03-26-2013 10:39 PM
Lap timer button? Longhorn248 BRZ First-Gen (2012+) — General Topics 15 01-14-2012 08:51 PM
