| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Kouki-Monster
![]() I'm a little frustrated .. maybe with myself. I pulled the trigger on 18x9.5 Forgestar F14's with a +38 offset. I am running a 235/40/18 tire all around. For suspension I have HSD HR coil-overs and my height up front is pretty "flush" no gap. 1-finger gap from sidewall to fender lip. I have -1.3 camber up front. Now .. on the street it's perfect. However on a track it's useless. The rubbing is brutal under any serious cornering. I really don't understand how anyone can say this sizing "fits" with no issues. I've seen some people reporting track use with the same sizing .. or even a 255/35 which makes no sense to me. I went out to an auto-x course and the front was absolutely horrible. Silly me for not doing some better measuring but .. what gives?
Rich Anderson
EMPOWER AUTO Last edited by DarrenDriven; 03-17-2014 at 01:18 PM. |
#2 |
Where exactly is it rubbing?
#3 |
Kouki-Monster
There's a black mark on the inner fender (non painted part, just inside the fender lip) about 3 inches long.
Rich Anderson
EMPOWER AUTO |
#4 |
Kouki-Monster
took the paint right off of the fender lip on the drivers side
Rich Anderson
EMPOWER AUTO |
#5 |
Who told u it would fit no issue when dropped on coilovers? I have this setup at stock suspension, and i know i cant drop my car w out excessive camber, which i personally wont do. Maybe they meant it was ok at stock or maybe a small drop?
#6 |
Drives: WRB BRZ
what is your spring rates on your coils?
Sounds like you are too low. 18x9.5 really isn't an ideal wheel size for the fronts for competition on a stock car.
#7 |
Drives: '13 BRZ in WRB--let's mod!!!
You'll need to double that camber setting. My car has coilovers 17x9s +35 w/ 245s w/ -2.5 & no issues.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD * '22 Z51 Vette--sold. * '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties. * '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot. |
#8 |
Kouki-Monster
Lesson learned. I am going to go up 0.5 inches and get my camber dialed in once my bolts show up.
Rich Anderson
EMPOWER AUTO |
#9 |
Drives: 86 ZN6
Buy a second set of wheels for the track. 17s ftw!
18x9.5 up front is all for show but no go on stock body! |
#10 |
001 of 012
Drives: MY12 NZDM Subaru BRZ "BRZ001"
I run the same set up wheel set up with 245/35 rubber with -2.0 degrees front camber. Car gets tracked and B road blasted regularly.
I've had no rubbing on track and only with a really BIG g out (its happened twice in 6 months) do I get rubbing in the rear. MOAR camber on the front
BRZ001: Peace Love and Wheelies @metabrz on IG
#11 |
With coilovers on 18X9.5, I think a 1 inch drop or so is sufficient. I don't see a heavy drop benefiting unless you really mess with the camber adjustment. The stock spring is already a fingernail away on a +38 18X9.5 with a 245/35 tire. If I can get a little more spring clearance, there'd be no problem with hard cornering or rubbing.
#12 |
Drives: Scion fr-s
I seen you on the track Sunday in Edmonton, I was going to come over and introduce myself but by the time I got down there you had left. I was also planning to run 18x9.5 wheels all around with 235/40 rubber. I won't be tracking my car often but I don't want any rubbing issues either. I'm wondering now if I should change my plans for wheels. I am lowered on Eibach Sportlines so I'm probably not quite as low as you so maybe I will get away without rubbing.
#13 |
NASA SpecE30 Racer
More front camber is the answer here. I will be getting my setup fine tuned over the next week, and I will definitely report back what I have to do to ensure I get no rubbing on my 18x9.5 +40 265/35/18 setup.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#14 |
Let's not forget that you are also running a taller than stock diameter tire too..by .8"
| Wheel Directory: Advan GT 18x9.5 +40 | FT-86 SpeedFactory | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 12-05-2017 07:26 PM |
| Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 | mav1178 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 09-13-2014 04:09 AM |
| Wheel Directory: Forgestar CF5V 19x8.5 +?? / 19x9.5 +?? | Mr. Joshua | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 08-21-2014 11:17 PM |
| Wheel Directory: Forgestar F14F 17x9.5 +38 | lp87 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 07-02-2014 02:41 PM |
| Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 | JRoldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 03-07-2014 08:10 AM |
