Old 03-22-2015, 03:17 PM   #1
Gunman
Drives: 2019 Mazda Miata RF
MPSS in the cold
OEM Primacy's are starting to get low on tread, so I'm starting to think ahead on tires. The Primacy's kinda sucked in the cold, and awful in the little bit of snow we get in NC, which I noticed a lot the first winter, with my short drive to work. By my second winter with the car, I had a longer commute, so the tires had a chance to warm up, and they weren't as bad in the cold, and I didn't even bother when we got snow.
So, my question is, how to the Pilot Super Sports compare to the Primacy HP's in the cold? I'm guessing very similar, since both are "summer tires"?
Old 03-22-2015, 03:30 PM   #2
Burrcold
Drives: Subaru BRZ Limited
MPSS's are worse in the cold. They get very slippery. You would probably be better with the Pilot Sport A/S 3's.
The Following User Says Thank You to Burrcold For This Useful Post:
Gunman (03-22-2015)
Old 03-22-2015, 04:32 PM   #3
Cuchullain
Cuchullain's Avatar
Drives: 2013 GBS Subaru BRZ Limited
From my experience, temps under about 40F will make the MPSS suddenly very slippy. Like able to break traction in the middle of a gear going straight slippy. At least until you get some heat in them. I would not recommend driving on the MPSS at anything close to or under 30. You could probably get away with not killing yourself (probably) but it certainly wouldn't be fun.
Cuchullain is offline   Reply With Quote
The Following 3 Users Say Thank You to Cuchullain For This Useful Post:
Black Tire (03-27-2015), Gunman (03-22-2015), wparsons (03-22-2015)
Old 03-22-2015, 06:13 PM   #4
gravitylover
Well shoot. You guys just extended my search time for new shoes but that's the info I needed. I also need new rubber soon and reasonably high performance tires that function well in the cold is important. Maybe not as much so as in the rain but I don't want to have to run the dedicated winter tires unless snow is imminent. Some winters around here we can go with minimal snow but it's always colder than summer tires are intended for. This year they were necessary frequently and I'll keep them on for another week or so but the rears are shot after 11k miles.
The Following User Says Thank You to gravitylover For This Useful Post:
Koa (03-22-2015)
Old 03-22-2015, 06:18 PM   #5
Koa
@gravitylover will send you two primacy HPs with low mileage for cost of shipping and like 30-40 a tire if it helps ya.. sucks to hear too because up here in the PNW temps get chilly in the winter. Oh well, proper winter tire and summer setups it will be
Old 03-22-2015, 06:27 PM   #6
gravitylover
^^ That's a maybe. I'll let you know in a day or two. Thanks.
Old 03-22-2015, 08:21 PM   #7
dp1
driving smoother faster
Drives: Sold
MPSS in the cold
Winter tires are better in temps below about 45F, regardless if it is dry, wet or snow...and not just in snow. If you don't have two sets of wheels, all seasons like A/S 3's would be a reasonable compromise...but they will not be great in summer or in snow. The more expensive option is more optimal year-round for any location where temps drop below 45F for long enough to warrant having both. I'm in north east and I own four sets of wheels (summer, winter and two for track/ax), neither of which have all season tires. I use mpss for summer street and wet track.
dp1 is offline   Reply With Quote
Old 03-22-2015, 10:14 PM   #8
Cuchullain
Cuchullain's Avatar
I do have to say, I think the MPSS is absolutely fantastic in the wet. I would even go so far as to say they might be better than the Primacys.
Old 03-24-2015, 07:24 PM   #9
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
FWIW, it is 4C/39F and dry here today and I just swapped my CEWC snows for new MPSS last night. Even fresh, the MPSS have more grip than the snows in these conditions. Not sure about when it gets below freezing and I'd never want to have to try the MPSS in the snow! There is supposed to be freezing rain tomorrow, so I'll be driving the wife's Golf on snows. I'm looking forward to trying the MPSS in the wet once it warms up, though. They look like cut slicks.
BTW, with lightweight rims the ride on the MPSS is actually slightly better than stock but man are they noisy. I'm running 225/45 on 17x8 720Form GTF1s.
Talus1 is offline   Reply With Quote
The Following User Says Thank You to Talus1 For This Useful Post:
Old 03-24-2015, 07:32 PM   #10
swarb
I believe the stock tires have a warranty to 30k. From what I read from some thread here, you can warranty them and use the credit towards another set of michelins.
Old 03-24-2015, 08:51 PM   #11
8R6
8R6's Avatar
Drives: FRS
toyo proxes 4 are decent all-season tires while maintaining decent performance
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Gunman (03-24-2015)
Old 03-24-2015, 10:49 PM   #12
djliquidsteele
Drives: Scion FR-S
People blow things out of proportion. It got down to -10F here and I kept my MPSS on all winter. Just don't drive like an A-hole and you'll be fine. Save the spirited driving for warmer days.
I will say, just i case anyone misconstrues what I said, they SUCK in any snow whatsoever. Downright dangerous even. I drive my wifes Optima anytime it snows. (She's usually off since she's a teacher).
djliquidsteele is offline   Reply With Quote
The Following 2 Users Say Thank You to djliquidsteele For This Useful Post:
Black Tire (03-27-2015), Gunman (03-24-2015)
Old 03-25-2015, 10:45 PM   #13
gravitylover
Thanks for the offer but I think I disliked them enough that I'll pass. I got the car with 14,500 on the clock and two of the stock tires were nearly shot and the others that weren't sucked in the rain. Working' on options now because the winter shoes will be coming off next week. I know you also do a lot of miles, I'll let you know what I decide on and how they hold up.
Old 03-25-2015, 11:18 PM   #14
dp1
Drives: Sold
Tirerack.com - MPSS Product Description - While Pilot Super Sport tires are designed to allow sports cars, sporty coupes, performance sedans and supercars to achieve their full potential in dry and wet conditions, like all summer tires they are not intended to be driven in near-freezing temperatures, through snow or on ice.
What you can do and what you are advised to do...
WTT: 17x8 +35 TSW Nurburgring MGM w/ MPSS Cuchullain Wheels and Tires 2 02-14-2016 02:07 AM
WTT: 17x8 +35 TSW Nurburgring MGM w/ MPSS Cuchullain NY / NJ / CT / PA 1 03-15-2015 04:14 PM
MPSS + Eibach Pro Kit: Anything More I should do? JohnAyySays Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-25-2015 09:09 PM
Rims with MPSS--NoVa Lavalover Wheels and Tires 5 12-03-2014 02:31 PM
FS/FT:Enkei Raijin/ MPSS 18's loogs Wheels and Tires 9 08-05-2014 11:50 AM
