Old 10-05-2013, 11:45 PM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
MAP bar to PSI?
So trying to determine a few things on my car, most notably my actuator spring pressure and my boost gauge accuracy. I just put a new actuator on, that is suppose to be 8psi.
I uploaded a log with this post...
At max looks like my map reading is 1.25bar.
How does this translate to psi?
Converting this gives me 18.13psi, which i know is not correct. Using the info from this site....boostsource and this formula...
Absolute Pressure (psia) = Gauge Pressure (psig) + Ambient Pressure (psia)
That would then mean.... 18.13 - 14.7 = 3.43psi?
Thing is my gauge is reading around 8-8.5psi under full boost/WOT....AEM failsafe...
My old actuator at WOT full boost would read about 6psi.....
This new one is reading at 8-8.5 or so at WOT
So now really confused. Is it possible i setup the preload on the actuator arm wrong? Maybe thats causing the 8.5psi vs the 8psi, or is that small fluctuation acceptable.
But still wouldnt account for the weird datalog on the MAP sensor...
Any input...am i reading something wrong in my logs?
LOG HERE
Thanks all!
gdrider77 is offline   Reply With Quote
Old 10-06-2013, 03:16 PM   #2
jamesm
are you using the stock map sensor? it has limited range, mine maxes out around 5psi.
Old 10-06-2013, 04:42 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
^^That was my first thought to.
Old 10-06-2013, 06:53 PM   #4
gdrider77
gdrider77's Avatar
3bar map sensor.
Old 10-06-2013, 06:56 PM   #5
jamesm
Originally Posted by gdrider77 View Post
3bar map sensor.
maybe it's not scaled properly? if you can view your rom it's pretty easy to tell.. if the map scale values are 4.834/-2.901 it's still scaled for the stock sensor. you'd probably get a cel though for high or low input if that were the case, but who knows?
Old 10-06-2013, 07:17 PM   #6
gdrider77
gdrider77's Avatar
View my rom, do you mean like in ecutek??
Old 10-06-2013, 07:49 PM   #7
jamesm
if it's ecutek you can't, unless you know someone with an openflash that can pull it for you. who is the tune from? did the tuner know you were using a different map sensor?
Old 10-06-2013, 08:48 PM   #8
gdrider77
gdrider77's Avatar
Well, i can ask my tuner tomorrow, he is working on the car in the afternoon, so hopefully we can get it all worked out.
Old 10-06-2013, 09:06 PM   #9
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
You're in Denver? Atmospheric pressure there is not 14.7. It's more like 12.
But it does look like your MAP scaling has some issues.
Sellout is offline   Reply With Quote
Old 10-06-2013, 11:45 PM   #10
gdrider77
gdrider77's Avatar
yeah in denver. So would that mean i subtract 12 and not 14.7?
Old 10-07-2013, 02:33 AM   #11
Sellout
Mr. Cranky Pants
Sellout's Avatar
Usually. the norm for Denver would be right around 12, but it can go up and down from there. (meaning the atmospheric pressure fluctuates, but generally not much.)
Old 10-07-2013, 08:26 AM   #12
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@gdrider77 , get a boost gauge and compare the ECUtek log with the Gauge.
Old 10-07-2013, 02:13 PM   #13
gdrider77
gdrider77's Avatar
That is what im doing...its crazy. So my boost gauge (aem failsafe) is reading about 10psi. Ecutek is reading 1.25bar, which is about 18psi. SO somehow ecutek and my boost gaguge are about 8psi different?
Old 10-07-2013, 02:20 PM   #14
Sportsguy83
Drives: Limited BRZ
Formula to convert ECUTek Absolute Bar to PSI:
Abs. Bar *14.5- (Ambien Pressure)
Usually its Abs. Bar*14.5-14.7 (In your high altitude case, that might be ~12 instead of 14.7).
It seems your MAP sensor might not be properly calibrated. I doubt your Boost gauge would be 8 psi off.
