Drives: White Virgin frs
Will the ecutek stg 2 not do much with an injen intake?
Somebody told me it wouldn't do much since the short ram injen intake will confuse the maf sensor. I wanted to get the stage 2 since I already got my overripe, mid pipe, second cat delete, catback exhaust, and injen short ram intake. Should I even pay 800 for something that won't do much then?
#2 |
Drives: scion fr-s (RIP)
Visconti will do a custom map for you with the different intake. Ming "bogged" a lot on early throttle but he fixed it
| The Following User Says Thank You to thebear21 For This Useful Post: | Frsexxxy (04-14-2013) |
#3 |
#4 |
It doesn't matter what intake you end up with, if the tuner will adjust your tune it will be done via data logs from your car so it's more of a custom tune instead of an off the shelf tune.
#5 |
A tune is almost a must for intakes, if only for safety.
Intakes like Injen rely on tricking the maf into running leaner to get more power. A tune will make sure the AFR is safe in the long run, which is a risk with using the intake on a stock tune. |
#6 |
Correct. Listen to these people. If you get an intake(which in mind is a waste now) get a tune.
| The Following User Says Thank You to jflogerzi For This Useful Post: | 2forme (04-14-2013) |
#8 |
| wtb injen intake | hunter3232792 | Engine, Exhaust, Bolt-Ons | 6 | 01-10-2014 10:19 PM |
| Injen Intake | seven | Engine, Exhaust, Bolt-Ons | 4 | 03-09-2013 02:40 AM |
| P0172 Code with Injen Intake, will EcuTek tune help? | ron_jeremy | Engine, Exhaust, Transmission | 0 | 11-27-2012 12:22 PM |
| HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 02:31 PM |
