| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Raven 6MT
Amount of Brake Fluid....
Planning on completely replacing the brake fluid but I only have 1 Liter of fluid...should that be enough or should I have more on hand? Does anyone know the exact amount of brake fluid?
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
#2 |
Drives: 86
I did a fluid swap in mine recently. I can't tell you the exact amount of brake fluid the system takes, but I can tell you 1L is more than enough. I used aprox 0.75L when I flushed out my old stuff and replaced it with the new.
#3 |
Drives: 2013 scion firestorm frs
brake fluid.
1L should be enough if your just swapping it out. also remember if you open up the system to change it out you'll have to bleed the air out of it. good luck!
#4 |
More than enough you will only need at most 3/4 of a liter.
| Brake fluid leak.. | tintumz22 | Issues | Warranty | Recalls / TSB | 9 | 02-01-2013 03:20 PM |
| Racing brake fluid promo | MillersOilsUS | Brakes, Suspension, Chassis | 0 | 12-31-2012 11:29 AM |
| Track Day Brake Fluid | Skorov | AUSTRALIA | 2 | 11-11-2012 07:10 PM |
| $98 Brake Fluid Upgrade | Texas BRZ | Tracking / Autocross / HPDE / Drifting | 15 | 10-22-2012 02:50 AM |
| Brake fluid volume | celica73 | Tracking / Autocross / HPDE / Drifting | 1 | 08-20-2012 02:05 PM |
