Torque Wrench Needed For Exhaust Installs?
I'm a noob when it comes to working on exhausts since the only ones I've ever had were welded from the header to the tips. Do I need a Torque Wrench for the bolts on the clamps? If anything I know it would be a low in/lbs or ft/lbs for the bolts with the wrench or should I just go in with a regular ratchet/socket combo? I've got a badass Kobalt ratchet that has the gears in it which you just twist, kind of like the Kobalt screwdriver I have as well. Works awesome in tight areas with no movement.
I'm about to install my Nameless Axleback and just wondered if I should bother with a torque wrench or not. I just want no leaks and the proper tightening to be done. |
#2 |
Drives: Ultramarine FR-S (MT)
I'm a noobie so take my advice with a grain of salt. I also installed a Nameless Axleback myself (Check my journal!) and just hand tightened. It's been about 3 months and the bolts aren't going to budge.
I was also worried about torquing the bolt... but the real problem ended being the freakin rubber gaskets! However, I do recommend getting a torque wrench to install almost everything else! I bought a cheap one off Amazon and it's been working great. (And yes, I have checked it's calibration and it's spot on) PS You'll love the exhaust!
| The Following User Says Thank You to Books For This Useful Post: | FR-S Matt (02-12-2013) |
#3 | |
Can't wait to get the Axleback! |
#4 | |
SLO NO MO
| The Following User Says Thank You to Foobar For This Useful Post: | FR-S Matt (02-12-2013) |
#5 |
I'll probably end up snagging the Craftsman Dr. Digi 3/8 then to start with and get the 1/2 down the road if I need something for suspension/pulley bolts, etc. Thanks for all the help guys!
#6 |
Drives: '13 Scion FR-S Whiteout
Just to let you know that harbor freight is running a deal on the 3/8 Pittsburg pro for $12.99... I thought it was a great price also jack stands for $14. You just need to print out the online coupon which also comes with a 20% off that I added to the wrench
| The Following User Says Thank You to Jacob G. For This Useful Post: | FR-S Matt (02-12-2013) |
#7 |
Site Moderator
Drives: Stuff
I have a 1/4", 2 3/8"s and a 1/2". You'll need the 1/2" for some stuff generally (axle nuts, etc) but a 3/8" that goes up to at least 90 ft lbs is a good all around torque wrench if you just want one. I can cover 5 in-lbs up to 250ft-lbs with the ones I have
For exhaust, I'll sometimes torque the header bolts.. that's it.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#8 | |
I just wanted to make sure the clamps are secure without overtightening the bolts or stripping them. |
#9 |
Drives: ex500r
No all you need is a socket wrenches. I just took off my mid pipe and exhaust. I'm not sure about your front pipe and headers
#10 |
Add lightness!
Drives: 17' WRX
Just have to calibrate your elbow. Anything going into the engine block or anything that rotates I'd torque to spec. Anything else is gudentite.
#11 |
I'm snagging the Harbor Freight clicking one for 10 bucks after that coupon... hard to pass up even if it does break, but I won't be using it very often so it may work out best for me.
#12 |
Add lightness!
Drives: 17' WRX
Don't cheap out on a torque wrench. You are buying it so you can do things right, what's the point if you buy one that will be completely out of spec after 1 little drop? Most of those cheapie chinese wrenches are way out of spec right out of the box. Buy a quality wrench (craftsman, snapon, mac) and get it calibrated every few years or after a big drop.
Some background: I used to work in a precision measurement lab and I've calibrated torque wrenches amongst other things. |
#13 | |
Snap-ons are the best in the world, hands down, but come with a hefty price tag.
#14 |
Drives: it like he stole it!!
I don't think Ive bought anything from harbor freight that lasted more than a few months. I use a craftsman torque wrench has not let me down for the past 3 years. I usually recalibrate it every 2 months.
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
| Torque wrench... Vendors welcome | Freeman | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 01-23-2013 06:30 AM |
| Digital Torque Wrench - Holiday Special | blmw | Exterior Parts - The Rest | 6 | 01-14-2013 09:40 PM |
| Digital Torque Wrench - Holiday Special | blmw | Announcements, Contests, Giveaways | 12 | 01-14-2013 01:16 PM |
| Digital Torque Wrench - Holiday Special | blmw | Engine, Exhaust, Bolt-Ons | 21 | 01-14-2013 10:31 AM |
| Which type of torque wrench do you prefer? | Hanakuso | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 07-11-2012 05:17 AM |
