Drives: SCION FRS (MT) HOT LAVA
CEL After PERRIN Crank Pully Install
Hello,
Can someone tell me how to reset my CEL ? I installed a PERRIN Crank Pully and my check engine light came on. I checked to make sure I connected intake plug and it was all good. The car is running fine with no problems. Thanks for the help ! |
#2 | |
SLO NO MO
I think disconnecting the battery won't help either as the CEL persists through a battery disconnect? |
| The Following User Says Thank You to Foobar For This Useful Post: | milko002 (02-01-2013) |
#3 |
Add lightness!
Drives: 17' WRX
You should go to autozone or pep boys and at least see what the code is. Could be something serious. Pulling the negative terminal on the battery then waiting about 5m should clear the light. The cel will still be stored though.
| The Following User Says Thank You to industrial For This Useful Post: | milko002 (02-01-2013) |
#4 |
Drives: 2013 Asphalt FR-S
As others have said... pull the code... could be totally unrelated either way... it only takes a few minutes to pull it and know for sure. Blindly resting check engine lights is a very bad practice.
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | milko002 (02-01-2013) |
#5 |
Here are the code that were pulled at autozone. P0113 and P0102. When I started the car the CEL was gone
. Hope I'm all good.
#6 |
Drives: Attitude
Make sure your MAF is plugged in tightly.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | milko002 (02-01-2013) |
#7 |
The plug is on the way it should be. If the CEL comes back I'll let you guys know.
Thanks for all the help! |
#8 |
yeah, those are both maf codes.. Did you happen to try to crank the car before you plugged the maf back in?
~Namaste~ |
#9 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
The second time I installed a crank pulley on a BRZ the CEL came on.
It was the intake. I didn't push it in far enough when reconnecting it to the inlet at the front of the engine bay where it connects in front of the airbox.
#10 |
Drives: accord
actually, you can try to reset the CEL light by disconnect the battary, wait for a few min then reconnect.
its throwing the CEL light because it thinks the engine is accelerating RPM under the same input condition. it should reset the RAM memory store within your ECU for idel condition. also when you turn on the car after reconnecting your battary, let the car sit at idel for a while. your car will first idel at 1K rpm, it will then slowly drop down to around 650 I did a writeup on this a while back with both light flywheel and light pully. |
| Aftermarket Crank Pulley Install | Enigmus | DIY (Do-It-Yourself) Guides | 305 | 02-05-2019 12:37 AM |
| Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 07:45 PM |
| Perrin/Brand 'Y' Crank Pulley ? | rikdrt1 | Engine, Exhaust, Transmission | 1 | 09-10-2012 05:39 PM |
