Old 04-28-2014, 01:48 AM   #1
Dezoris
Dezoris's Avatar
Quick Autox Video | 2nd in Class
Was out finally getting to do autox testing on Ohlins dampers learning how car changed vs. stock suspension.
The course was designed by Miata drivers for Miata drivers, very tight, complex. Most difficult part was getting hands to switch from standard, to shuffle to changing positions fast enough to get through transitions.
After doing more track and karting recently it took me a bit to get back to this. I hate shuffle steering and changing hand positions.
Quick Settings Note:
  • Ohlins Dampers set to 7F 8R of 20.
  • Pedal Dance Used
  • Turd Hawk HPS fronts used with oem rear pads, need to go back to 1521s
  • RS3s 34FR 34FL 33RL 33RR, nearly perfect temp/roll
  • Was about half a second off pace
[ame="https://www.youtube.com/watch?v=aDWA8YeknWY&"]Supercharged FRS BRZ Autox Test | In Car Only - YouTube[/ame]
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
Lonewolf (04-29-2014), SportInjected (04-28-2014)
Old 04-29-2014, 01:13 AM   #2
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
Nice job. That us a crazy tight course.. All of the tight corners make for a lot of speed changes. I hate it when a course doesn't flow. A good course design should not favor one vehicle type but challenge all vehicles. The Miata guys probably hate seeing an FR-S messing up the final results list.
MTCRX is offline   Reply With Quote
The Following User Says Thank You to MTCRX For This Useful Post:
Dezoris (04-30-2014)
Old 04-29-2014, 01:45 AM   #3
Lonewolf
Lonewolf's Avatar
Drives: Moped
See, now aren't you having fun with her?
The Following User Says Thank You to Lonewolf For This Useful Post:
Old 04-29-2014, 06:06 PM   #4
stock
stock's Avatar
Drives: 2015 FRS Steel (manual)
i'm impressed.
How is the FRS on slaloms? I used to h4te slaloms.
stock is offline   Reply With Quote
Old 04-29-2014, 07:36 PM   #5
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
How are those Turd Hawk Pads? I've been thinking about poopgrading...I mean, upgrading, lol.
Thrustin is offline   Reply With Quote
Old 04-29-2014, 07:41 PM   #6
bobaab
Drives: 13 Subaru BRZ Limited
Hey, met you at the autocross this past weekend! I was the guy in the silver BRZ.
Amazing what good driving, supercharging, and a good tire/suspension setup can do! My best was a 55.326, the only thing not stock was the exhaust (switched to a Nameless muffled track pipe to save about 20 pounds).
It was my first autocross with the car, so I'm still learning a lot about it. It feels a whole lot different than my 06 Miata and especially different from the 91 MR2 I used to drive.
I couldn't get the hairpin turn leading to the gated slaloms, it was a tough turn for me...the car understeered like crazy. The first Chicago Box was quite interesting too, and I couldn't figure out the best time to brake for it was. The second Chicago Box was a bit more intuitive for me for some reason.
Gonna stay fairly close to stock during this season, so it'll be nice to compare time with you. I'll do simple things like get an alignment (the camber bolts have been sitting on my desk) and maybe a drop in filter replacement. A set of sticky tires if I feel like spending some cash.
Hope to see you around, you'll have to take me around in your FRS next time!
bobaab is offline   Reply With Quote
Old 04-30-2014, 01:23 AM   #7
Dezoris
Dezoris's Avatar
Originally Posted by stock View Post
i'm impressed.
I used to be horrible in slalom, but it clicked for me one year and have never had an issue since. FRS/BRZ very quick and easy to keep neutral, stock suspension included.
Quiet, not dusty perfect for Sprint kit on street. But the turd pad material dont work, for stopping power.
Thanks! Watched your afternoon runs working course, I could tell you were very smooth and have a ton of potential in the car. It was very hard to tell outside where you could pick up speed but I think you have the pace, just need to go more flat out where you can.
I tend to blow my first 3-4 runs making all my mistakes to see what I can get away with and figuring out pavement grip for launching etc. Then focus on smoothing out afternoon runs. The hairpins are a pain in the ass you just cant try and be fast in those zones. Go in smooth, go out smooth.
The BRZ understeers, and to make matters worse in a stock class you have no factory camber adjustment on the car. You could swap in the camber/crash bolts max out front camber with them and that should get you away from under steer. I am sure you will figure out what works the more you drive.
I will be there this weekend in the S2000 and back following week in FRS again. I will try and ride with you one session and see how things are going.
Quick AutoX class question Thongpocket Tracking / Autocross / HPDE / Drifting 3 02-18-2014 02:38 PM
stupid video i made for a class wrb BRZ Photos, Videos, Wallpapers, Gallery Forum 13 02-12-2014 01:51 PM
Track and Autox Video Dezoris Tracking / Autocross / HPDE / Drifting 0 05-06-2013 02:38 AM
Autox and Trackday video trippinbillies40 Tracking / Autocross / HPDE / Drifting 0 04-07-2013 06:35 PM
2nd BRZ autox w/ video and pics nubbster927 Tracking / Autocross / HPDE / Drifting 1 09-12-2012 06:26 PM
