Old 01-16-2013, 07:15 PM   #1
fiveoneone
Drives: 86 White GTS
18x9.5 +30 in the rear
Can anybody running 18x9.5 +30 offset in the rear on here confirm that they fit without camber adjustment? Any need for guard rolling?
Photos would be great.
Please state what tyre size you are running as well if you can.
fiveoneone is offline   Reply With Quote
Old 01-16-2013, 08:12 PM   #2
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
I know 18x9.5 +38 with a 285/30/18 works in the rear without trouble.
Tansey86 is offline   Reply With Quote
Old 01-16-2013, 08:24 PM   #3
fiveoneone
ye i know +38 is fine without camber adjustment or guard rolling but not sure about +30
Old 01-16-2013, 10:09 PM   #4
Supermassive
Supermassive's Avatar
Ok, enough people have asked about rolling the fenders...they come rolled from the factory...
Supermassive is offline   Reply With Quote
The Following User Says Thank You to Supermassive For This Useful Post:
_F-R-S_ (01-16-2013)
Old 01-16-2013, 11:10 PM   #5
fiveoneone
oh really? i was told that the fronts were but not the rears from someone who has a toyota 86
Old 01-16-2013, 11:12 PM   #6
_F-R-S_
Drives: 13 whiteout scion frs
They all pre rolled.. If you do t lime it get a bat
_F-R-S_ is offline   Reply With Quote
Old 01-16-2013, 11:15 PM   #7
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
so if i have an 18x9.5 +40 on my rears with a 265/35/18 will fit without camber adjustment and running oem alignment and height specs? could i even do a 275?
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 01-17-2013, 02:46 AM   #8
Tansey86
Tansey86's Avatar
Run that through the tire fitment calculator that guy made. It seems pretty accurate and will give you a good idea. I'd think you'd be alright though.
http://www.frsproject.com/tire_size.php <---Use this
Last edited by Tansey86; 01-17-2013 at 02:47 AM. Reason: Found Auto Fitment Calculator
The Following User Says Thank You to Tansey86 For This Useful Post:
sal (01-17-2013)
Old 01-21-2013, 06:53 PM   #9
ScionFR-S
ScionFR-S's Avatar
wow thanks man... i wonder if a 275 would fit tho , everyone says that a 255 is close to rubbing but with stock height it will probably be an easier fit
Old 01-21-2013, 10:19 PM   #10
RAYSSPL
Drives: bicycle
bump because i'm wondering as well
RAYSSPL is offline   Reply With Quote
Old 01-22-2013, 12:42 AM   #11
ScionFR-S
ScionFR-S's Avatar
bump
Old 01-22-2013, 12:46 AM   #12
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
The fenders aren't rolled the lip is just non existent. Any bat work would give you a pull and likely turn out like shit.
dorifuto is offline   Reply With Quote
Old 01-22-2013, 01:04 AM   #13
Tansey86
Tansey86's Avatar
Crawford fit a 285/30/18 with a 18x9.5 +38 wheel. Width wise it will fit probably up to a 295 on each side, its a matter of height with the sidewall(i.e, a 285/40/18 would probably not fit)
Wheel Directory: XXR 530 18x9.75 +20 alexfrspr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 02-09-2017 09:02 AM
Wheel Directory: SSR Professor SP3 18x9.0 +24 / 18x9.0 +20 RZ86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 05-18-2013 05:14 AM
Enkei 18x9.5 +38 Front and Rear Pictures maj75 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 12-10-2012 04:02 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 02:52 AM
17x9 +35 front .... 18x9.5 +38 rear kinryu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-30-2012 03:19 AM
