Old 10-09-2012, 10:14 PM   #1
Zagmeister
Zagmeister's Avatar
Drives: 2013 FR-S Ultrmarine MT
Do I Really Need TPMS with my After Market Winter Package?
I found and priced a couple of winter package options (wheel and tires) for my Scion FR-S.
However, with the "full" winter package - which neccessitates new TPMS sensors - the sensors would have to be initialized at our Toyota / Scion dealership.
Moreover, this also means that EVERY TIME you switch between the OE wheels / tires and the after market winter package, you would have to go back to the dealership to reset your TPMS system for the specifc sensors being used for the season. Toyota and Scion have one setting of the TPMS sensors, so they only accept one set of four sensors at a time.
I was also assured that if I chose not to include TPMS on the winter package (only wheels and tires) the TPMS red light indicator would go away once I reinstall the original OEM set of wheels and tires, without having to go back to the Dealer for re-initiation.
Any prior experience, advice, opinions, or comment? Thanks.
PS. I hope I'm not duplicating other threads on the same topic.
Zagmeister is offline   Reply With Quote
Old 10-09-2012, 11:55 PM   #2
Buzzy
Car Guy
Buzzy's Avatar
Drives: FR-S,2 RX-7 s,Maverick, 67 F-100
The idiot light drove me insane on my Expedition Max so I did it after a month if looking at the light.
Buzzy is offline   Reply With Quote
Old 10-09-2012, 11:59 PM   #3
gmookher
how hard is pulling dash bulb?
Old 10-10-2012, 12:02 AM   #4
Zagmeister
Zagmeister's Avatar
I would hope it would be easier to pull a fuse controlling the TPMS dash bulb, if it's connectining only that bulb.
Old 10-10-2012, 10:38 AM   #5
FRiSson
Drives: FR-S MT
Someone posted a video on how to eliminate the light, but it wasn't something I ever want to tackle. You have to take apart the dash.
There are definitely some people not getting TPMS sensors in their winter set. Tire Rack has a list of states that require them.
http://www.tirerack.com/wheels/tech/...jsp?techid=214
FRiSson is offline   Reply With Quote
Old 10-10-2012, 10:57 AM   #6
jadewbj
jadewbj's Avatar
Not sure how much they charge you to mount and unmount tires. You could have them take the sensors out of your stock rims and put them in the winter tires. Then switch them back when you go back to summer.
jadewbj is offline   Reply With Quote
Old 10-10-2012, 11:01 AM   #7
NOHOME
Drives: RAVEN
$100 a pop is the answer. Maybe a bit more at the dealer. Dealer will warn you about possible damage to transmitters anytime the job is done and it wont be their fault.
NOHOME is offline   Reply With Quote
Old 10-10-2012, 11:03 AM   #8
SpeedR
First86 / boat thief
Drives: MKIV Supra
Its my understanding that the car will catch fire with out the TPMS system.
And if you put 87 in the tank it self-destructs. Literally it blows up. I’m so cereal Literally booom!!!
SpeedR is offline   Reply With Quote
Old 10-10-2012, 11:05 AM   #9
jadewbj
jadewbj's Avatar
I hope that is not 100 per tire! I only paid 24 per to have it done to my new rims.
Old 10-10-2012, 11:06 AM   #10
K2
First 8600
K2's Avatar
Drives: Gen2 GR86
I'm looking at getting one of these little monsters.
http://www.ateqtpm.com/products/tpms.../ateq-quickset
K2 is offline   Reply With Quote
Old 10-10-2012, 11:07 AM   #11
CaptainSlow
CaptainSlow's Avatar
Just deal with the light...I did that when I had my Mazdaspeed3. Just wasn't worth the cost. I just checked the tire pressure once a month or so, and called it good.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 10-10-2012, 11:11 AM   #12
Burrcold
Drives: Subaru BRZ Limited
I'm assuming you need the Toyota TPMS sensor? I have winter rims and tires from my GTI that I will be using on the FR-S. They already have a sensor on them...not sure if they would work though. Probably not.
Old 10-10-2012, 11:15 AM   #13
KevinR
Drives: 1993 Turbo Miata, 2013 Asphalt FR-S
How much does it cost to program the TPMS sensors at the stealership each time?
KevinR is offline   Reply With Quote
Old 10-10-2012, 11:34 AM   #14
sajonf
Drives: 13 Scion FR-S, 12 Camaro ZL1
I drive around every day with my aftermarket wheels and tires without sensors in them. The dash light doesn't bother me one bit. It flashes for a few seconds then lights up solid.
As a matter of fact I only see it when I drive more than 50 miles I think. Every morning when I start my car with my stock wheels in the garage right next to it they register correctly and only come on 50 or so miles later. So I only ever see the light when I drive a long distance without turning the car off.
sajonf is offline   Reply With Quote
dealer initialization, tpms, winter tires
Best double-din on currently on the market? Hanakuso Electronics | Audio | NAV | Infotainment 15 05-29-2013 01:58 AM
After market security shiud Electronics | Audio | NAV | Infotainment 5 09-28-2012 03:59 PM
16" or 17" for winter? Blue rims on blue car? TPMS or not? Deslock Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 12:33 AM
Question about US and OZ market FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 2 06-12-2012 11:08 PM
how many dads here are in the market for a FR-S? stlgrym3 Scion FR-S / Toyota 86 GT86 General Forum 52 02-21-2012 12:35 AM
