Old 02-26-2010, 10:45 AM   #1
Orly
Drives: 03 Civic Si
Larger Rear Wheels - Tacky or Acceptable?
This idea never crossed my mind since I've always owned front wheel drive cars (/duckandcover), but say you put 16x8's on the back with 16x7's on the front (or a similar variation) to get a semi staggered look you see on other sporty RWD cars - Tacky? Acceptable? Useful for drifting? Over the top for this little car? Ok for the weekend?
Whats your opinion?
Orly is offline   Reply With Quote
Old 02-26-2010, 11:01 AM   #2
Infernal
NO FI?! (╯°□°)╯︵ ┻━┻
Infernal's Avatar
Drives: BMW e92 330D
im not sure but id imagine smaller thinner wheels would be best for drifting - thinner contact patch means less grip and more sliding around - plus - the smaller the whee. the less torque is required to spin it, therefore being able to wheelspin because less of your available torque is used up trying to spin a big 22 inch wheel around.
i guess it depends on what you want. Id like big wide wheels personally because id like the car to be getting better traction off the line - some will want less traction because they want to slide all over the place
Infernal is offline   Reply With Quote
Old 02-26-2010, 11:10 AM   #3
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
That is fairly common for RWDs. Some of the dudes on the Supraforum run 18 fronts and 17 rear just so they can shoe on bigger rubber.
I say it's a must on this car :happy0180:
Old 02-26-2010, 11:52 AM   #4
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Drives: '08 xB '07 Yaris '06 EVO9 '89 240SX
Just an FYI... Drifting is all about grip, the more grip you have the faster you can drift.
Biggie™ is offline   Reply With Quote
Old 02-26-2010, 01:50 PM   #5
Matador
hashiryu
Drives: Mk4 Supra
Whats your opinion?
...... You have got to be kidding me...
I know jack all about drifting (outside of what is required while rallying) but... that just doesn't sound logical, or you left out a big part of the equation.
Matador is offline   Reply With Quote
Old 02-26-2010, 02:06 PM   #6
Midship Runabout
formerly Dixie Normous
Midship Runabout's Avatar
Drives: The ladies wild!
Some cars came with a staggered width. Like the mr2
Midship Runabout is offline   Reply With Quote
Old 02-26-2010, 02:13 PM   #7
Orly
Drives: 03 Civic Si
Matador - Something confusing? Its a simple question of what people prefer, what works and what doesn't.
Old 02-26-2010, 03:10 PM   #8
RRnold
2 wheel member
RRnold's Avatar
If they are AWD then the wider ones go in the front. Other than that, staggered wheels on this car is a must.
Old 02-26-2010, 05:40 PM   #9
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
you need grip for control.. drifting is all about control
VenomRush is offline   Reply With Quote
Old 02-26-2010, 05:43 PM   #10
TheStig
Something Clever
Drives: 2009 BMW 135i, 2006 Civic (Beater)
Kind of alot of questions you threw in there. But to answer it simply: I would love it. Not necessarily for drifting, but simply for added stability and...(I have to admit) for looks!
There are quite a few cars that use staggered setups, just to name a few: 350/370Z, G35/37, S2000, Most BMW's w/ Sport pack, RX-8, etc.
TheStig is offline   Reply With Quote
Old 02-26-2010, 06:20 PM   #11
mike2100
mike2100's Avatar
Drives: 23 BRZ
RX-8s don't come staggered. At least the 04-08s didn't
If you go staggered you better know what the hell you are doing (same goes for any mod that affects driving dynamics). IMO sacrificing drivability for looks when performing any modification is dumb.
mike2100 is offline   Reply With Quote
Old 02-26-2010, 06:21 PM   #12
Blokatos
Drives: MX5 Miata Mk2.5 1.6
Different sized wheels/tyres combo front to rear comes natural only in mid engined/ rear drive or rear engined/ rear drive cars.
In a front engined car, different sized wheels/tyres combo are a way to mask suspension setting issues and poor chassis R&D.
Blokatos is offline   Reply With Quote
Old 02-26-2010, 06:23 PM   #13
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
Its a common misconception that drifting is complete and total loss of the rear wheels. There's actually still grip going on in the rear during a slide, and its that grip, countersteer, and throttle management that keeps you from spinning out.
If you put smaller wheels on the rear (in my picture, the rear wheels are the 1986-1987 factory 'snowflake' alloys, coming in at 14x5.5, 1.5 inches smaller than my fronts) and crappier tires, you create oversteer, but you also lose grip in the rear, making it MUCH harder to slide at any speed worth noting. Its extremely easy to spin out.
You have to find a balance between creating oversteer and maintaining some form of grip in the rear. Part of creating oversteer has nothing to do with the tires (though matching your tires with this part is very important) or wheel selection, rather, damper and spring rates on the both the front and rear.
There's obviously the other end of the spectrum. Too much contact patch in the rear / too sticky a tire (for your power output) and you'll have a very hard time creating a drift you can control.
OldSkoolToys is offline   Reply With Quote
Old 02-26-2010, 06:33 PM   #14
TheStig
Something Clever
Explain to me how it sacrifices drivability.
The only major downside is if the car doesnt have close to 50/50 weight distribution, then either the front or rear tires will wear faster.
I have had staggered tires on numerous cars that I have owned, including my current 135i which has aftermarket 19's on it. 19x8.5 and 19x10. It drives just as great as it did when I had the stock 18's on it. I have never had any problems with anything...
Rear Seats? KyShro Scion FR-S / Toyota 86 GT86 General Forum 57 05-27-2010 11:04 AM
Sex on Wheels S2KtoFT86 Other Vehicles & General Automotive Discussions 14 12-02-2009 10:14 AM
what are your thoughts on rota wheels? VenomRush Other Vehicles & General Automotive Discussions 46 11-24-2009 03:08 AM
Rear Seats? joshuo Scion FR-S / Toyota 86 GT86 General Forum 27 11-06-2009 11:37 AM
Wheels on the Prototype joshuo Scion FR-S / Toyota 86 GT86 General Forum 13 11-03-2009 07:37 PM
