Drives: 2013 Raven FR-S
Is this normal?
Everything is lined up per the DIY, the silver clamps go on and off easily, all the teeth are lined up and I have been out for a few drives and it feels and sounds fine. Still, never had the border of an air filter peek out. it looks worse in the picture than what it is, as the box is actually closed and the seal seems air tight.The entire filter elements is even on all sides and completely contained within the airbox, but the polyurethan wants to peek out on some of the sides......
is this normal to see the polyurethane a little bit? |
#2 |
No, you should not be able to see the filter edges. It's not locked in fully from the looks of it or the filter needs to be adjusted a bit more.
#3 |
heres a few more...
#4 | |
followed the DIY exactly and still got this |
#5 | |
Drives: 86GTS
I think you might need to flip the air filter over the other way for it to fit properly. |
#6 |
ok....looks like I will have to install it for the 3rd time.....these air filters are a bitch!!!! its like impossible to get it to sit properly the fit is down to the smallest millimeter. kinda ridiculous
EDIT: just reinstalled it for the 3rd time, it has to be normal i measured everything.....someone on here has to have the TRD with the same problem or another air filter with similar unless the TRD is a faulty designed filter maybe.... Last edited by BlackyRose; 10-04-2013 at 12:18 PM. |
#7 | |
#8 | |
The actual filter element fits perfect but the polyproplene surround seems a little big, again, maybe its that way to create a seal, I am not sure, maybe I will call TRD |
#9 |
I would, I have never seen a filter not fit inside an airbox and seal completely with the poly material sticking out. That's a sign the filter doesn't fit the box unless its by design and is still sealed. Still doesn't look right though. Those are supposed to be sealed, tight connections.
| is it normal? | Minovsky | Issues | Warranty | Recalls / TSB | 5 | 04-23-2013 12:56 PM |
| Does this look normal to you? | white_knight | Issues | Warranty | Recalls / TSB | 13 | 03-03-2013 04:10 AM |
| Is this normal? | ArKiTeCkT | Engine, Exhaust, Transmission | 3 | 10-29-2012 03:54 AM |
| Is it normal to see a .... | Mango22 | BRZ First-Gen (2012+) — General Topics | 10 | 10-12-2012 03:54 PM |
| Scion goes normal | terrypm | Other Vehicles & General Automotive Discussions | 21 | 05-02-2012 11:16 AM |
