Australian and Proud !!!!
Drives: 2012 Toyota 86 GTS Aero Kit
Broken Wheel Nut on new rims
Hi guys I bought a set of composite Alloy wheel nuts and the last night I put on the 4th wheel sheared off as I was torquing them up. It is tight against the wheel what is the best way to get it off?
BONKRS for life
#2 |
Drives: RX8 S1
Oh man so it snapped in line with the threads, not down the length??
Your best bet is to get a chisel and try to brake it. If that don't work you need to drill the stud out.. This is why noone, ever, should get aluminum nuts..
#3 |
Drives: Scion FRS Firestorm MT
You mean CHEAP EBAY ones right?
I'v used lots of nuts from differenet brand (not cheapos) nuts - and NEVER had any problems... Even our race car is running on Rays aluminium nuts for last 3 years - and never ever had any problem.. Ussualy people overtight them - and then blame it on for them beeing aluminium. Its pretty easy to read over and find torque settings for all the nuts - and use a torque tool... Easyest way to take off broken nut - is just to drill the stud out and replace it with new one. |
#4 | |
Drives: RX8 S1
aluminium nuts are a throw away item. They should be used once. Period. Regardless of the brand. This is from a metallurgical point of view. You can argue with annecdotes all day of you want to ![]() Also since al alloys distort differently to steel alloys, as you said, they should be torqued slightly differently.
#5 |
Drives: B4C Camaro, 2005 MINI JCW, Civic
Aluminum lug nuts? Why would anyone even make such a thing? The liability would be crushing. What is the point of using them? It seems like a risky way to save a small amount of weight.
#6 |
Saving them pennies...
I used 5zigen aluminum lugs for over 6 years. Torque to 80 pounds with a torque wrench that gets checked and calibrated every year.
Never had any issues. If you don't have a torque wrench you shouldn't be putting them on with a gun or by hand. |
#7 |
#8 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
I am all for lightweight, but would never use AL lug nuts.
I've had enough trouble with AL spoke nipples on bike wheels, that I use brass and save weight in the spokes/rims instead. |
#9 |
Drives: Nevermorange FRS
I'm going to make pewter lugs nutz... That'd by tyte yo! Pewter is da new bling y'all!
:I'm going to go bang my head against the wall now: |
#10 |
Buzz Killington
Drives: A slow truck
Aluminum lug nuts are intended to be used only once. When you torque them to the correct setting they stretch, a lot. Personally I don't see the point, just use some quality steel nuts or Ti if you have the money.
Sent from my PC36100 using Tapatalk 2 |
#11 | |
Re-member
Drives: Toyota camry
Sorry but one case does not an argument make. Aluminum is too soft, you got lucky.
Nothing decays like progress, and nothing preserves like neglect.
#12 |
These are what I used
BONKRS for life
#13 | |
Reverse Burnouts
Drives: 2013 Argento FRS
or you can buy a tq stick for your impact and just got to town, i dont use wrenches on my FRS because the handle comes too close to the body, afraid i will harm something :P
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#14 |
Drives: 2013 Raven FR-S
I've used Al nuts for my past few cars with no problems, weren't particularly high end, nor were they the cheapest ones available either. Always want to make a point of visually inspecting them for any flaws, and be sure that its snug in the key. Also, as has been stated never over torque!
edit add: I also use my impact to throw em on usually because its faster lol, but i'll usually hit em with a tq wrench after for the final tightening... I had a friend in highschool who didnt check tq and almost lost a wheel while driving.. 1 nut fell off before we noticed- scary stuff. |
| Broken Sun Visor | feldy | Issues | Warranty | Recalls / TSB | 99 | 10-10-2022 10:33 PM |
| Heart broken.....Subaru brz | FT86FRS | CANADA | 26 | 09-09-2012 03:45 PM |
| Broken window = out of commission. | Mitch | BRZ First-Gen (2012+) — General Topics | 11 | 09-02-2012 11:04 PM |
| First brz broken into...sigh | zex | CANADA | 74 | 08-04-2012 05:17 PM |
| Broken Window Help! | zex | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 07-28-2012 03:54 PM |
