Old 09-18-2013, 11:06 AM   #1
Perry
Drives: 86 Raven
17 x 9 +42 Wheels on H&R SUPER SPORT
Anyone here with this? Im planning to go with these set up just want to know if you had problems with the setup?
Perry is offline   Reply With Quote
Old 09-18-2013, 03:31 PM   #2
Toyobaru808
i believe with a 245/40 there will be ~3mm clearance between the tire and stock stut. someone said that it will not fit while others say it will. either way it gonna be a tight fit with stock struts.
I have 17x9 +42 on 245/40 all around w/ kwv3 and there is no issues what so ever. kw's are much slimmer than stock struts though
Toyobaru808 is offline   Reply With Quote
Old 09-18-2013, 03:34 PM   #3
Toyobaru808
http://www.ft86club.com/forums/showthread.php?t=7678
first post show it just fits with stock springs and struts
Old 09-18-2013, 11:41 PM   #4
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
like previously mentioned, it'll fit but it'll be really close to the spring perch up front. you pretty much can't run any camber at all or it'll rub. a few people have shaved the spring perch about 1-1.5mm to be able to run a little negative camber
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
Old 09-19-2013, 02:32 AM   #5
Perry
Drives: 86 Raven
What if its 235/40 will it fit also?
Old 09-19-2013, 05:00 PM   #6
Toyobaru808
not sure about that size, most ppl go 245/40 bc its close to stock diameter
H&R Super Sport Perry Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 10-09-2013 03:20 PM
H & R Sport Springs (not Super Sport) dewitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-28-2013 09:01 PM
FS: H&R Super Sport Springs frs4mark Brakes, Suspension, Chassis 8 05-11-2013 04:17 AM
H&R Sport & Super Sport Springs for FR-S / BRZ @ Guerilla Racing GuerillaRacing Brakes, Suspension, Chassis 5 01-11-2013 05:20 PM
Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers Diego@lutzperformance Brakes, Suspension, Chassis 1 10-04-2012 01:43 PM
