Old 07-15-2024, 10:13 PM   #1
amaurya
Drives: 2016 BRZ Limited
Exclamation Exhaust leak near headers
Hello all,
Recently I’ve been having issues with my 2016 BRZ. I’m confident I have an exhaust leak near my headers however haven’t been able to confirm this as I am away for work and won’t be home for another month. The car “sputters”, for a lack of better term, when starting from cold and has delayed throttle response when starting from a stop. I’ve driven this car for 5 years now and I know where the bite point is and is and I have to feather the throttle a little more to get it going. However once the car is fully warmed up, it drives fine with no obvious issues making me believe the leak is sealed due to the metal expanding when hot. At the moment I park my car in a parking garage overnight and when I start the car the in the morning, no sputtering, however after work and the car sitting outside for ~9 hours, it sputters when starting. I’m in California so the car isn’t cold. I do have aftermarket headers but they’re only 3 years old so I’m hoping they’re not cracked. I’m very confused as to what is causing this anomaly with the leak depending on where the car is cold started and would appreciate any possible insight into this. I included my mods list and a sound clip of it starting after work
Thanks in advance
Mods list:
Ftspeed UEL headers
Nameless performance catback exhaust
Ptuning flex fuel kit + stg 2 tune
https://youtube.com/shorts/vu5KL40DR...USsKwGs8fNzRJA
amaurya is offline   Reply With Quote
Old 07-16-2024, 06:07 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Get under and look for signs of leaks. Dripping water on cold-start, cracks on joints/pipes, loose fasteners, or sooting
  • You can also spray some soapy water, but you have to do it close to cold-start or else it will vaporize instantly and won't give you any indication (also thermal shock not good for pipes)
You have a flex fuel kit, so it could be something related to your fuel, fuel map / response
Delayed throttle response could also mean MAF, dirty throttle body, or bugged idle learn
EndlessAzure is offline   Reply With Quote
exhaust leak, help needed, repair
Possible exhaust leak after headers? Attached data log Fairlight Engine, Exhaust, Transmission 3 04-19-2021 10:05 AM
Exhaust Leak hpanju Engine, Exhaust, Transmission 8 01-03-2020 12:55 PM
Oil leak onto headers after dealer repair of P0018. PDXsuperfly Issues | Warranty | Recalls / TSB 4 02-12-2018 09:55 PM
Possible exhaust leak? dar3d3vil Engine, Exhaust, Transmission 10 02-21-2016 08:45 PM
Exhaust Leak help? ray7792 Engine, Exhaust, Transmission 4 07-04-2014 02:08 PM
