Old 09-28-2012, 01:35 PM   #1
jeebus
CEL U0155 - Lost comm with cluster
This morning I reset my ECU because well, I felt like it. My car had been running just fine but I was curious how long the BRZ takes to go through it's readiness monitors, etc. I have almost 3k miles on the car.
After I reset, I drove about 15 miles and plugged in my code reader while driving. All but 2 readiness monitors had finished by then. I was happy to see the car goes through them pretty fast.
5 miles later, I was at a light. Plugged in my code reader again. WHILE I was plugging in the code reader, a CEL came on. U0155. WTF? So I tried driving and the car was in limp mode. Lame. Pulled over and googled to find that it indicates lost communication with instrument cluster.
I reset the code and drove another 20 miles. So far so good. The CEL has not come back. I'm wondering if it was some sort of a fault I caused while plugging in the code reader? I've never had a car with an OBD2 that was sensitive to being plugged in while driving, maybe this one is?
Anyone else care to chime in?
jeebus is offline   Reply With Quote
The Following User Says Thank You to jeebus For This Useful Post:
Guff (09-28-2012)
Old 09-28-2012, 01:56 PM   #2
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
My bluetooth ODB reader kept causing this code and the gauges to die. It just doesn't like some. Turns out my unit was completely dead as it wouldn't work on other cars anymore either. I assumed the failure was due to it being bad but or yours it continued to work?
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 09-28-2012, 02:00 PM   #3
gmookher
what odb2 reader do u use?
Old 09-28-2012, 02:22 PM   #4
jeebus
ok, good to know. I had a feeling I caused this. Yes, my reader still worked after this.
I can't remember what reader I have, but it's a decent one. Like $150.
boonFRS (04-01-2016)
Old 09-28-2012, 02:25 PM   #5
Kido1986
Dodging cones
Kido1986's Avatar
I was using the Blue and Orange Bluetooth ELM327 (not the solid blue one, know issues with that one)
Old 09-28-2012, 05:34 PM   #6
Dezoris
Dezoris's Avatar
Yes certain, OBD2 readers cause this code to come up and other codes like U0073.
And it usually happens with the reader plugged in during startup.
Old 01-11-2014, 07:18 PM   #7
TM
TM's Avatar
Drives: DGM BRZ 6MT
This happened to me today, too, when I plugged in my openflash tablet. I used the tablet to erase the code and drove 300 miles. It didn't never came back.
TM is offline   Reply With Quote
Old 04-22-2014, 06:16 PM   #8
DC2R
Drives: 2014 Scion FR-S
Same with open flash tablet and extension from Amazon. It reads fine but didnt like to write using cable
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 04-29-2015, 12:35 PM   #9
Juggles
Drives: 2013 FRS
Codes U0155 and U0073 happen to me on occasion if I leave my bluetooth reader plugged in.
Fix: Don't leave it plugged in
A zen master once told me "Do the opposite of everything I say", so I didn't.
Juggles is offline   Reply With Quote
Old 09-17-2015, 09:02 PM   #10
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Just got a U0073 when I left torque pro open and running while I ran into a local store. The car was off but torque pro kept talking to the ecu. I guess the ECU doesn't like this. OBDLINK LX was used. I can get this to repeat if I leave the app open with the car off. I need to check to make sure it's going to sleep.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
2013GTRNate (01-19-2016)
Old 01-19-2016, 09:28 PM   #11
2013GTRNate
2013GTRNate's Avatar
This happens to me all of the time with Torque Pro and Nexus 7(2013).
SYMPTOMS: Sometimes my car will start but promptly stalls out and will not start until I pull the battery cable and reset the ECU.
SUSPECTED REASON: Forget to close out TORQUE PRO before turning off my BRZ.
This is super annoying but what other options are available for monitoring the ECU?
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
Old 02-18-2019, 06:22 PM   #12
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
Thanks for this, put me at ease since I had my first CEL. Indeed I have been leaving my ODBII reader plugged in for months, never had this come up though... I typically close Torque when I leave the car because it stays in my notification bar otherwise and I didn't this weekend which boom resulted in CEL.
slizoth is offline   Reply With Quote
Old 04-28-2019, 10:46 PM   #13
whatsupemt
Drives: 2015 Scion FRS
Angry
I just had this happen a minute ago.I left Torque Pro on and engine off to change clothes and when I jumped back in the car voila, cel U0155 code.Used Open Flash Tablet, cleared code, reflashed same CPB tune and now no cel.Apparently my 15 Scion FRS doesn't play well with Torque Pro or OBD Link lx
whatsupemt is offline   Reply With Quote
Old 09-15-2019, 05:18 AM   #14
HSV Guy
Drives: Not a HSV (2017 BRZ)
I just had the exact same thing happen to me in my 2017 BRZ. Last night I turned my car off with Torque [Lite] still running in the background and then this morning when I started my car the check engine light came on and I have the U0155 error code.
How did you guys clear the permanent DTC/has anyone tried the below? I'll give this a go myself when I next get the chance and advise how it goes.
Originally Posted by https://www.autoserviceworld.com/carsmagazine/taking-a-first-look-at-permanent-dtcs/
Universal Trip Drive Pattern
So, how to clear a Permanent DTC? By performing a Universal Trip Drive Pattern that meets the strict criteria in the repair manual, to prove to the computer that the fault has indeed been repaired and no one is trying to cheat on an emissions test. After performing this Drive Pattern, if the code doesn’t clear it’s usually because the strict criteria were not followed exactly. It’s a pain, but that’s the way it goes.
Typically, this Universal Trip Drive Pattern starts off by clearing all the DTCs so that only the Permanent DTC remains (always refer to service information for applicable information and procedures).
Then turn the ignition ON, start the vehicle and let it idle for at least 30 seconds. Then, without cycling the key, drive the vehicle for at least five minutes at more than 40 km/h. Then (again without cycling the key) let the vehicle idle for at least 30 seconds before shutting it OFF. The whole drive cycle must take at least 10 minutes. After performing a Universal Trip Drive Pattern, the computer clears the code, since it’s “seen” that the problem is fixed and not reoccurring. Sounds simple enough, and most problems have apparently come from not performing the Universal Trip Drive Pattern correctly, but time will tell if these new DTCs will be problematic.
HSV Guy is offline   Reply With Quote
Removing gauge cluster surround Gen Cosmetic Modification (Interior/Exterior/Lighting) 8 04-25-2013 11:28 AM
Scratches on my Cluster. Superhatch BRZ First-Gen (2012+) — General Topics 5 08-21-2012 08:50 AM
Lost fans? 315FR-S Off-Topic Lounge [WARNING: NO POLITICS] 11 05-31-2012 05:13 PM
2013 FR-S (Auto) Cluster Startup Sequence xravexboix FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 05-21-2012 07:36 PM
